Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 22-01-2005, 13:23
dtknowles dtknowles is offline
#0500 (CGATeamUSA)
dtknowles is an unknown quantity at this point
Exclamation CMUCam2 Help!
We have plugged our camera into a 7-volt power supply. The red and Green LEDs stay on and we cannot get any signals from it. When we plug it into the computer, our terminal emulator stays blank and the Configuration program just says Looking for camera... What's wrong?
Unread 22-01-2005, 13:34
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
Re: CMUCam2 Help!
this thread has some discussion thread
which com port is the config using? which com port is term emulator using? are you using them at the same time?
Unread 22-01-2005, 13:35
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: CMUCam2 Help!
Have you followed the debugging flowchart in the CMUCam documentation?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 23-01-2005, 11:33
#0500 (CGATeamUSA)
Re: CMUCam2 Help!
The COM settings look correct. The manual says something about having to install the firmware. Could this be the problem? If so, how is this done?
Unread 23-01-2005, 11:35
#0500 (CGATeamUSA)
Re: CMUCam2 Help!
I really need to know what the red LED means.
Unread 23-01-2005, 21:53
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Re: CMUCam2 Help!
The red LED is most likely user LED 1 that turns on when powered. Make sure your COM ports are enabled in the BIOS. If you use a USB to serial adapter the serial port id starts at 5 or 6. In either case check your device manager by right-clicking My Computer -> Properties and go to the hardware tab. Under ports make sure your COM ports are installed and are working correctly and you are using the right number. Try other simple ovelooked things. Try using a different serial cable. Make sure the power is sufficient.
Unread 23-01-2005, 23:26
Re: CMUCam2 Help!
The red LED on our camera lights up when it is successfully tracking a color. It corresponds to the camera status message coming back with a nonzero detected size, which we use to activate one of the OI LEDs.
Unread 25-01-2005, 21:56
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
Re: CMUCam2 Help!
where do u get the CMUCam2GUI at, cause i can't seem to find it ne where, and i need it to get my cam to work, so if u can plz help me find where to get it, it will be greatly appreciated.
Unread 25-01-2005, 22:03
Re: CMUCam2 Help!
ifirobotics.com
Unread 25-01-2005, 22:52
Re: CMUCam2 Help!
where at there, anywhere specific?
Unread 25-01-2005, 23:05
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: CMUCam2 Help!
To purchase a new or extra CMU-Cam2 unit you have to call Innovation First Inc. Their phone number is on the bottom of every page at their website, http://www.ifirobotics.com/. I am not sure what the cost is but when you call they will give you all the information you need.
-Michael Dessingue
Unread 25-01-2005, 23:25
Re: CMUCam2 Help!
It's not too terribly hard to find - from the IFI page, click on the CMUCam link and download the 'Getting Started' pack.
Unread 25-01-2005, 23:28
Re: CMUCam2 Help!
o, ok, thxs dude
Unread 25-01-2005, 23:54
Re: CMUCam2 Help!
ok, i got the files, and now i am looking for which one exactly to use with the Java to get the cam to work on the comp, so i can figure out the best place for them to put it and make sure it is working correctly and everything. it isn't like i can test it out or anything till tomorrow though :/
Unread 26-01-2005, 09:34
Re: CMUCam2 Help!
It's all explained quite clearly in the document labeled as "Getting Started" or "Start Here" or something like that.
CMUCam2 Vision Sensor Testing/Problems cbolin Programming 18 02-02-2005 18:03
Random Tranformer and What do the CMUCam2 LED's do? swarm32 Technical Discussion 9 15-01-2005 23:51
Where is the CMUcam2 code? Matthew_H Programming 1 14-01-2005 17:49
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
CMUCam2 Neal Probert Programming 7 13-01-2005 21:02
