Go to Post I think we sometimes forget that FIRST is not just about building robots. Its purpose is to educate and inspire young people in the field of science and technology. - amanda [more]
Unread 23-01-2005, 15:01
VideoMan053's Avatar
VideoMan053 VideoMan053 is offline
Computer Freak
AKA: Dan J.
FRC #0063 (Red Barons)
VideoMan053 is an unknown quantity at this point
Send a message via AIM to VideoMan053
Exclamation Potentiometer Trouble ??
For our robot we are using an arm that is in three sections. If you remember from nationals last year, it is similar to the "Hot" bot, team 67. We need to control this through a potentiometer. I need to know how to set up this system to control the arm.
Team 67, if you are reading this, can you please send me some of your code from last year.
Thanks
GET OVER IT! ~ not the most useful words in competitions, but some of the most useful in life!
My Jobs: Programming
Unread 23-01-2005, 15:06
Bharat Nain's Avatar
Re: Potentiometer Trouble ??
It seems that you are doing something very similar to what we did last year. If you can get in contact with me either through AIM/AOL or e-mail I am willing to share our setup and programming code with you. Visit our website www.raiderrobotix.org and see if our bot is similar to what you are thinking.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 24-01-2005, 20:06
Computer Freak
AKA: Dan J.
Talking Re: Potentiometer Trouble ??
Okay, i understand how to set the pot up now.
My next question is where can i get a 30K potentiometer that is legal in the first competitions?
Unread 24-01-2005, 20:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Just about any decent electronics supply shop will have them. They're not a rare part. Radioshack might even have them
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 24-01-2005, 23:24
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Why 30k? The manual suggests that you use 100k, which will also be easier to find.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2005, 23:32
I think you are going to have a tough time finding a 30K pot. Standard values (i.e. stocked values) are most often either 25K or 50K. Some of the larger parts houses like Newark and Allied might have standard values but then 30K is still not a standard value.
Unread 24-01-2005, 23:51
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
A few other notes when you go looking for a pot. Theres a couple major things to think about when purchasing a potentiometer from anywhere. These include whether you want an audio taper or linear taper pot and also whether you want "10-turn" or single turn pot.
A linear taper pot has the same change in resistance for every degree it is turned, while an audio taper pot normally has different ranges of change of resistance. All the applications Ive used pots for in FIRST have primarily used linear taper pots.
Now onto the amount of turns. This is where it will normally come down to the application the pot is being used for to choose which type is best. If what you are measuring the amount of turn on goes less then 360 degrees a single turn pot normally is what you would use and would have more precision for small amounts of turn. A "10-turn" pot is like the name suggest a potentiometer that will turn more then one complete turn and is used normally on devices that can do more then one complete rotation.
[Al or anyone please correct me if im wrong and i searched how-stuff-works for more in depth explainations but it seems they dont haves pots described there.]
-Michael Dessingue
Unread 25-01-2005, 09:32
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Indeed. It's worth a bit of time getting a decent pot, since while you can prototype with an el-cheapo pot, once you've got the bot together, make sure you are using a nice pot.
Cheap pots have a lot of problems. The big ones are drift and non-linearity. Minor problems include poor resolution and directional hysteresis (giving a different value whether you turned the pot CW or CCW to get there).
I've usually used fairly high-end ($11 or so) 10K pots from digi-key (look up part number 6639S). Good linearity, little drift. They are single turn with no stop (so they wrap around from 10 kOhm back to 0 ohm at 0 degrees), but other than that they've been very, very reliable.
Unread 25-01-2005, 09:53
Keep in mind that single-turn pots often only have about 270 degrees of freedom while designing your hookup...
Unread 25-01-2005, 21:43
Fat Alex's Avatar
Fat Alex Fat Alex is offline
Mr. super uber ultra Alex
AKA: Alex
#0060 (Bionic Bulldogs)
Fat Alex is on a distinguished road
Send a message via MSN to Fat Alex
I was looking for a pot like that, though, the price seems kinda steep... anyone have another recommendation?
exactly what I was looking for was a continuous pot, 100k (for Operator Interface), it would only have to be accurate to 10 degrees or so...
also, to achieve 360 degrees with only 320 or whatever of effective electrical angle you could use two pots offset and sort it out with some good old fashion programing.
Shake the hand that shook the world
Unread 25-01-2005, 21:48
I usually pick up my three-quarter-turn pots for about a dollar and the ten turn pots at about $6. How much is too much?
Unread 25-01-2005, 23:21
Fat Alex's Avatar
AKA: Alex
Well if I wanted to use the ones kaszeta suggested I'd use two because I need 360 continuous rotation, and that would cost 20 bucks, which seems overkill for the lowness of the resolution I want. I guess 5 or so a piece would be ok...
(also: thanks for the reply)
Unread 25-01-2005, 23:34
If you need 360 degrees, either grab a three-turn pot (never bought one, but I would assume it would be a couplea bucks), and if you want continuous rotation go for some sort of {optical|mechanical} encoder.
Unread 26-01-2005, 00:04
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
That may not always be satisfactory. I have an encoder that clicks 32 times per revolution. This turns into 8 counts per revolution in code when using interrupts. With a continuous pot, you may get up to 1024 counts per revolution. If you were counting something that went fast and didn't need too much precision, like the drive train, then you would use an encoder, so you could monitor it with hardware interrupts. If you were using something that was slower and in need of more precision, but still made multiple rotations, like a winch or something, a continuous potentiometer would make more sense, because you wouldn't need interrupts; you could just poll it every 26.2ms without missing any data. While it is safe to say that it's always a good idea to use a potentiometer when you're making less than one complete revolution, encoders are not always the ideal solution for multiple revolutions.
_
Unread 26-01-2005, 09:36
Well, if you're willing to pay, you can get encoders which have multiple millions of stops (probably even more) per revolution. It is, however, by no means the be-all and end-all solution.
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
I'm having trouble sleeping!! archiver 1999 5 23-06-2002 22:38
New Haven ball trouble Jeff Rodriguez Regional Competitions 1 04-04-2002 21:47
