Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
Unread 23-01-2005, 16:38
Pattie Pattie is offline
Pattie will become famous soon enough
Re: Motor Placement Pros and Cons
Hi Cyberwolf. Thanks for the response. You say you had this design at one point - what were the reasons you did or did not use this design? Were there any fatal concerns with this design?
Pattie
Unread 23-01-2005, 16:42
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
The reason we eventually decided against it was that we were going to go with a 6-wheel drive train if the chains connecting the wheels broke we wanted out center wheel to stay powered so in the end we decided to put the motor in the center of the robot. In addition, it put the weight above our center wheels.
Unread 23-01-2005, 20:00
occra 23.
AKA: ryo
None #1481
well just an imput from a lego stance, i have used this in many lego models with much success. but lego is slightly different as most of you know. why i used it in lego, because haveing them in that config allowed me to leave the minimum width to 5 blocks rather than 10
Unread 24-01-2005, 01:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I didn't take a look at the word document, but because our gearboxes are so large we are placing one at the front right wheel and one at the back left wheel. Not optimal but functionally the same.
Unread 24-01-2005, 11:21
Have you had any issues with driving crooked at all?
Practicing after Ship - pros & cons Natchez General Forum 24 18-01-2005 23:06
Team 871 - Homebrew Segway MrB General Forum 140 06-07-2003 16:21
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
Buckeye Regional PROS and cons emilywll Regional Competitions 14 18-03-2002 10:04
