Go to Post your bot brings all the boys to the yard. - looneylin [more]
Unread 23-01-2005, 16:48
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
3 motor drive train
I was wondering if teams will start going to 3 motor drive trains since first made it sooooooo easy to have 2 motor drive trains.
Unread 23-01-2005, 16:54
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: 3 motor drive train
Why would you use an odd number of drive motors?!
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 23-01-2005, 16:58
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
3 per side. 6 Total.
-Rod-
Team 662
Colorado Springs, CO
Unread 23-01-2005, 16:59
oreocookeee oreocookeee is offline
Critic Extraordinaire
AKA: orie
#0810 (Mechanical Bulls)
oreocookeee is on a distinguished road
Send a message via AIM to oreocookeee
i think he means three motors per side, totaling six motors. i guess you would add the fisher price motor somehow. i dont think it would be worth the trouble. in that case, you might as well design it from scratch, which most teams are already capable of.
nuggetsyl's Avatar
FRC #0025
why not
Unread 23-01-2005, 17:00
nuggetsyl's Avatar
FRC #0025
yes i mean 6
Unread 23-01-2005, 17:07
phrontist's Avatar
Proto-Engineer
You'd need a whole mess o' differentials and torque converters and all sorts of nasty stuff to make an odd number of motors work...
Unread 23-01-2005, 17:08
nuggetsyl's Avatar
FRC #0025
not really just the right gear ratio
Unread 23-01-2005, 17:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Says who? all you have to do is match their speeds. Plenty of teams have done it. 45, 494, 188, etc.
And there's definitely an advantage. If you figure out how to keep the FP's cool, and not draw a ton of current with them, you've got a 5th and 6th CIM in your transmission, for all practial purposes
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2005, 17:15
nuggetsyl's Avatar
FRC #0025
i think changing gears on the fly is over rated.
Unread 23-01-2005, 17:18
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
It's surprisng how many people post without reading the whole thread. Phrontist is talking about an odd number of motors total. The thread starter meant 3 motors per side, 6 motors total. An odd number of motors total in a normal skid steer design would definitley be no easy feat.
As for 6 motors, I do not expect a great increase in the number of them. First of all, I don't think the gain is that great because every 4 motor robot i have seen loses traction before it puts too great of a load on its motors. Also, if you use your FPs, you aren't left with much power for your arms between the remaining motors.
Team 1257
Unread 23-01-2005, 18:34
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
In my opinion it will be better to have 3 motors on each side, however that just gives you more stuff to worrie about and more things that can go wrong. I'll rather stay with two reliable ones, also the FP motor burns easily.
David
Unread 23-01-2005, 19:00
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Show us your numbers...
Decisions concerning the number of motors in a drivetrain (2, 4, 6, 8, 10, 12... whatever!), the number of speeds in a drivetrain, and what speeds to gear at, are engineering design decisions.
These decisions are dependant on a robot's gearing, wheel traction and many other factors.
The output power from the motor must be modified (via gearing) to be "optimized" to achieve desired performance. Sometimes more power must be added (more motors) and sometimes the gearing must be modified for different tasks (multiple speeds). There are many different definitions of "competitive performance". There are also many different combinations of drivetrain components tha can be used to achieve these levels of performance.
Note: for more information on drivetrain physics, shifting gears, or multiple motor drivetrains, please click the *search* button.
To imply that this decision can be universally made for all drivetrains, without showing any calculations
(i.e. "6 Motor drive is stooopid. Long Live 4-motors...") is foolish.
I urge everyone: keep your opinion to yourself; unless you have some calculations to back it up.
Thanks,
John
Unread 23-01-2005, 20:51
Alyna's Avatar
Alyna Alyna is offline
#0408 (The Roboticks)
Alyna is an unknown quantity at this point
Wouldnt that be a 6WD?
Unread 23-01-2005, 21:09
Mohsin's Avatar
Mohsin Mohsin is offline
building...building...bui lding...
FRC #0772 (Club Sandwhich)
Mohsin is on a distinguished road
Send a message via MSN to Mohsin
well wouldn't it be a waste of power, as well as weight, because, the weight of the gearbox that FIRST gave us this year is heavy, imagine adding another moter to, as well as the gears needed to get the ratio and the speed right. and the power part, well six motors drawing the power all at the same time, which 2 motors could do, or even 4 is, well alot, leaving little power for the arm, but it might work if you are a pushing robot only. also the chances of something breaking or screwing up are greatly increased. which is always bad in the competion.
Mohsin
Team 772
If it aint broke, get INCENTIVE
[ECDU]:drive train Michael Leicht FIRST-related Organizations 3 03-08-2004 16:23
To Maximum Oz and Two Train Joe Matt Thanks and/or Congrats 1 09-03-2003 13:03
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
