Re: Pneumatic Piston Weight
From the 2003 pneumatics manual:
Approximate weight calculations for custom cylinders, not including the rod clevis or pivot brackets: 3/4" Bore 0.21 lbs. + 0.03 lbs. per inch of stroke 1/2" Bore 0.73 lbs. + 0.08 lbs. per inch of stroke 2" Bore 1.62 lbs. + 0.15 lbs. per inch of stroke |
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| Breaker Panel weight | Emily Pease | Electrical | 4 | 24-01-2005 12:22 |
| Robot Part Weight List | Don Wright | Technical Discussion | 3 | 20-01-2005 12:55 |
| How can i mount a pneumatic piston to a pvc pipe!?!?! | archiver | 2001 | 4 | 24-06-2002 01:11 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
