Go to Post When your team becomes ubiquitous with the phrase "Always a bridesmaid, never the bride" - Peyton Yeung [more]
Unread 23-01-2005, 19:32
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Backup battery will not power RC
I'm hooking up our RC to make sure everything works, and I ran up against a problem. The backup battery, despite that it's hooked up, will cause a red light on the "Backup Batt" light on the OI and, upon removing the 12V main source, it will not power the robot. I have verified with the multimeter that the battery is charged (~7.8V) and even tried a different battery. Any other things I can try before assuming that it's a broken RC?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 23-01-2005, 19:35
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Backup battery will not power RC
I've noticed that, with the new firmware, the backup battery will not keep the RC powered indefinitely like it did last year. If you watch the RC when you disconnect the main power, the power light will go orange for a few seconds before turning off. I'm not sure what the reasoning behind this is.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2005, 19:43
Electrical Engineer
Rookie Year: 1995
It sounds as if you both have dead batteries...
We have had no problems with the 2005 RC and backup batteries. However, I will do a test tomorrow to find out how long the RC runs with a backup battery after the 12V power is disconnected and report on the results on this thread tomorrow afternoon.
Mike Betts
As easy as 355/113...
Unread 23-01-2005, 19:47
Bharat Nain's Avatar
I think he is right. I have a fully charged backup battery, and it too turned off a few seconds after I disconnected the 21V battery. I just tested this(Yes, I have a bot sitting right next to my feet.)
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 23-01-2005, 19:50
Strange. If I have a servo plugged in, it will not power anything. As soon as I unplug the servo, the battery light goes off and all is well. It even keeps running after I remove the main power. But, the instant I plug the servo back in, it all dies.
Unread 23-01-2005, 19:57
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Nope... fresh off the charger. I'm guessing that it's a function of the new firmware, unless another team can confirm that their backup battery keeps their RC powered for longer than a few seconds.
_
Unread 23-01-2005, 20:02
Electrical Engineer
Rookie Year: 1995
As Alice once said: "Curiouser and curiouser!"
Mike Betts
Unread 23-01-2005, 20:12
Hmm. Looks like a shorted servo or something...
Unread 23-01-2005, 20:37
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
We've experienced the same thing. It seems to be a function of the new firmware. With the old firmware, when you shut of the breaker, the robot controller would stay on until you reset it, draining the backup battery. There seems to be a 5 second shut-off delay now, which should be sufficient for covering most voltage drops.
Zan Hecht
Unread 23-01-2005, 21:00
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
I can definitely tell you that with the old firmware the backup battery did indeed keep the RC on. However I haven't had a chance to test the new master code, but I'll try it out whenever I get a chance and post my results as well.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 24-01-2005, 01:10
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Earlier today or late last night close enough to each other, I updated the firmware on our RC. I charged the backup battery a couple days ago and have been running it with a 12 volt jump pack running the robot electronics and testing the camera. today while just letting it run ( at least an hour) with the camera connected and a servo on the camera and 2 speed controllers and a relay all connected running properly and I had the dashboard viewer running. I watched the main battery fluctuate between 12.6 and 12.2 as I tested controls and watched the backup battery slowly die off fairly slowly. I walked away a few minutes and came back and saw the red light on the RC saying dead/low battery. Checking the Dashboard Viewer indeed it was dead, showed around 3 or 4 volts. I would have to say that the problem anyone would be having is simply a dead or low or disconnected.
And yes the RC does turn off after a couple seconds of only on backup, to save battery power.
just my little bit of experience
-Mike
Unread 24-01-2005, 01:27
russell's Avatar
russell russell is offline
#1430 (WRONG)
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I add my vote to the "its the new firmware" column. Ours does the same thing, and I have been wondering why. But even our 2004 bot does it (yes all of our batteries are fully charged), but I did update the firmware on it so I think that is why. I think this is so you dont have to always unplug the backup battery (a serious pain) just to turn the bot off. I was told that the backup battery was supposed to stop you from losing data when the battery goes dead, so I am guessing this new firmware just does some sort of safe shut down sequence in those last few seconds. Or something. I thought EEPROM was not supposed to loose data but whatever.
Mike: In previous years (last year anyway) when you shut down main power, if you had a backup battery plugged in the control system would continue functioning until the backup battery is unplugged. This new firmware seems to change things so that the robot still shuts down, it just waits a few seconds.
Unread 24-01-2005, 01:48
Mike AA's Avatar
AKA: Mike Aalderink
I understand that, I would have to guess its to save the battery and also acts like a "UPS" incase of a shortterm surge on the main. I would guess that if you still have a small amount left on the mail it would keep going getting a "blip" from the main. I like the function that it turns of as lastyears's team got annoying to turn it off or unplug it.
Unread 24-01-2005, 01:59
russell's Avatar
#1430 (WRONG)
I have to agree that I like it. Just for a while there I was wondering if there was something wrong with something.
EEPROM + Backup Battery Ryan Cumings Programming 4 28-02-2004 13:30
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
buy extra backup battery MaxM Electrical 2 20-02-2004 18:11
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
