Go to Post The bottom line is, what works best for YOUR team is what the best solution is. - EricH [more]
Unread 23-01-2005, 14:32
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Sliding door motor mounting holes
Does anyone happen to know the size of the three threaded mounting holes on the sliding door motor? I don't have it with me, and it'd be useful to know before tomorrow. Thanks.
Team 1257
Unread 23-01-2005, 15:00
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Sliding door motor mounting holes
This has our team stuck as well.
Are they metric? Whats going on with them?! We tried like every screw we had. What we did though was we took the KitBot screws, they go in like, just enough to hold the motor and then we used lots of washers to make up the difference that the screws wouldnt go in. That actually worked out quite well, look into using that and then when the right screw thread size shows up, just swap the screws.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 23-01-2005, 15:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I can check later today, but for now I seem to recall them being M5.
Unread 23-01-2005, 15:25
Mike33's Avatar
Mike33 Mike33 is offline
NOOOOOOOOOO! MY LAST YEAR IS OVER!
AKA: Keebler (Elf)
FRC #0033 (Killer Bees)
Mike33 will become famous soon enough
Send a message via AIM to Mike33
i beleive sanddrag is right. M5's should be it. I just remember the strict order to 'not lose them at all costs'
--"Always bear in mind that your own resolution to succeed is more important than any other one thing." --Abe Lincoln
Final Four in 2005 National Championship
2005 National Team Imagery Award
2005 West Michigan Imagery Award
2005 Detroit General Motors Industrial Design Award
2nd Place in Detroit and West Michigan
"Its a jeep thing, you wouldn't understand"
---copy the jeep and pass it around---
o_o_o_o
./| ,[_____],
|ŻŻŻL--O|||||||O
()_)Ż()_) ŻŻŻ )_)
(originaly made by my friend david)
Unread 23-01-2005, 15:59
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
Yes, they are available at any local hardware store. Bring the motor to make sure they are M5.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 23-01-2005, 16:36
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
Retap the holes 1/4-20, thats what weve always done, never had any problems with the threads stripping, and you dont have to worry about 'accidentally' losing those metric bolts :-p
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 23-01-2005, 16:56
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Team 662 has done the same thing with no problems.
-Rod-
Team 662
Colorado Springs, CO
Unread 23-01-2005, 20:11
The TechnoKats seem to be on the other side of the issue. From what I've seen in my software seat over the past year, one of the basic design rules is that every bolt on the robot is either M3 or M5.
Unread 23-01-2005, 20:16
Fold em oval!
Metric? Really? That's wierd. The majority of the components that already have holes that are used on FIRST robots are not metric. Metric are also a bit harder to find in as wide a variety of lengths, head types, etc.
Team 1257
Unread 23-01-2005, 21:02
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
I seem to recall them being M6, but I am at home with no way to check the threads.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 23-01-2005, 21:06
Fold em oval!
Anyone have a definitive answer?
Team 1257
Unread 23-01-2005, 23:26
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Over the past 4-5 years, they have been M6x1.0 threads.
Andy B.
Unread 24-01-2005, 00:47
negatory negatory is offline
AKA: Brandon C.
#0955
negatory is an unknown quantity at this point
isn't modifying the motors illeagal? or i am i just making up rules?
Unread 24-01-2005, 01:23
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Housings are fair game, so long as you don't make internal mechanical changes or electrical changes (per <R31>). There's another thread on this; http://www.chiefdelphi.com/forums/sh...ad.php?t=33313, where they discuss other modifications, specifically to the CIM.
Note that there's a related Q&A question pending, so this information may change.
How to cut flat sided holes for Globe and Door motor Max Lobovsky Motors 8 13-01-2005 14:09
Who is drilling holes this year ?? shyra1353 General Forum 28 02-12-2004 03:22
Making a series of spaced holes around a cylinder in inventor James114 Inventor 13 21-11-2004 18:44
Machine weight and holes archiver 2000 0 23-06-2002 22:51
Drill holes nick reynolds Rumor Mill 10 12-01-2002 01:39
