Go to Post Everyone here inspires each other and helps them out. That's why FIRST is amazing. - tiffany34990 [more]
Unread 23-01-2005, 21:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 3 motor drive train
Originally Posted by Mohsin
well wouldn't it be a waste of power, as well as weight, because, the weight of the gearbox that FIRST gave us this year is heavy, imagine adding another moter to, as well as the gears needed to get the ratio and the speed right. and the power part, well six motors drawing the power all at the same time, which 2 motors could do, or even 4 is, well alot, leaving little power for the arm, but it might work if you are a pushing robot only. also the chances of something breaking or screwing up are greatly increased. which is always bad in the competion.
Mohsin
Team 772
If it aint broke, get INCENTIVE
Im going to go out on a limb here and guess that with efficient weight reduction, you could make a 6 motor transmission that weighed the same amount as the current kitbot one, or slightly more. It's all a question of whether it fits the design criteria of your team's robot.
What do you mean by power? Draining the battery? sure, it does, but any team that makes a 6 motor drive will have considered that and deemed it an acceptable penalty.
You don't need motors for arms, you can use pneumatics, and there's still multiple motors left over if you use 6 drive motors.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2005, 21:40
ebenhopwil's Avatar
ebenhopwil ebenhopwil is offline
#0115 (MVRT)
ebenhopwil is an unknown quantity at this point
Send a message via AIM to ebenhopwil
Would a 6-motor drive train offer any significant advantage over a 4-motor? It wouldn't be any faster, but you would get more torque. But wouldn't you also need some hi-traction wheels to take advantage of that torque? And then there's the extra weight...
So my question is... is it worth it?
Unread 23-01-2005, 21:52
Cory's Avatar
AKA: Cory McBride
You can have a higher top speed, with more torque at that speed than a drive system with fewer motors would have.
2001-2004: Team 100
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Or some high traction treads . BTW I would like to thank JVN personally for creating his spreadsheet motor calculator. It helped me tremendously in designing my teams gearbox this year. John, i'll be shaking your hand at one of the competitions, good work man.
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Please everyone read JVN's post previously in this thread. It is all in how you gear it. Very few conclusions about drive systems can be made in general. You can go much faster with a six motor drive, you can much slower. You can have lots more torque, or a lot less. Adding more anything (motors, gears, etc) to a drive system doesn't amount to any generality other than more weight, but even that is debatable.
If we are looking to discuss a specific drive system, lets do so but lets refrain from making such general coments as "it wouldn't be any faster."
Unread 23-01-2005, 21:55
Mohsin's Avatar
Mohsin Mohsin is offline
building...building...bui lding...
FRC #0772 (Club Sandwhich)
Mohsin is on a distinguished road
Send a message via MSN to Mohsin
remember the CMI motors have weight, and if you use the other motors, the gears would have to use weight, but as for pneumatics well if you want to use them a lot, a compressor would be the best choice, but it adds weight and drains more power from the batteries, we found that out last year. and i will agree with you in the desigh criteria, whatever you wnat and think best suits your needs, build it
Mohsin
Team 772
Civil Engineers = Tree Huggers
Unread 23-01-2005, 22:02
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
From what I can tell (since I've never built a 3 or even a 2 motor transmission) the only thing to gain from a 3 motor transmission would be to push hard at high speed. After seeing the coefficient factor of different wheel types, your going to be hard pressed to keep any wheel/tread from breaking loose with 4 motors. I may be off ( I did some math, but I don't completely trust it ) I think if you took the kit bot setup and also used the highest traction wheels you could find (what's been used in the past anyway, unless you've got some new space age material you need to tell me about) - all 4 cims - 21-28 sprockets - You're still going to be able to break the wheels loose in a pushing match. That's without shifting - plain ole kit gearboxes. So, putting another motor on there... If you wanted to break your tires loose while pushing at 5'/s maybe? OK but why? Usually your just trying to hold some ground, not send an opponent into orbit. Or maybe you want to go 20'/s but you could forget about controlling it. Maybe you'll get close to stall if you increase your weight with a bunch of tetras or using the opponent bots weight to leverage it. Anyhow, like John said - I think most of the hype on 3 motors is just that - hype. Do the math and you'll see. I know of a team that seriously knows what they're doing, and they're considering 1 cim/side , 3 speed NBD's and tank treads.
Although we did modify the kit gearboxes to take the FP motors (and lightened them up), just because we could. They haven't been run with 3 motors yet, but it will be fun just to see how they perform. We aren't planning to use them for our competition bot though. If anyones interested in how to do this it's pretty easy. You need to mill that fat 50 tooth in half. Then you can put a 60 tooth 32 pitch gear on the end of one of the cim shafts. We welded the 14 tooth to the 60 tooth, then key it back on the cim shaft. Then you penetrate the other side of the gearbox for the FP to mate with that 60 tooth. It took us 2 days to do it. Maybe later in the season I'll host a vid of our comp bot pushing the 6 motor practice bot around
www.179swampthing.org
Unread 23-01-2005, 22:57
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
well on a similar note. 118 is actually going with only 3 chips powering all 4 wheels. Although they arn't coupled, you still can say it's a 3 motor drive train.
Unread 24-01-2005, 01:15
Care to enlighten us on exactly how this will work. It sounds very intriguing.
Unread 25-01-2005, 11:36
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Originally Posted by Max Lobovsky
As for 6 motors, I do not expect a great increase in the number of them. First of all, I don't think the gain is that great because every 4 motor robot i have seen loses traction before it puts too great of a load on its motors. Also, if you use your FPs, you aren't left with much power for your arms between the remaining motors.
If you want to be able to push and do burnouts while using "tall" gearing, using a Fisher-Price on each side along with the CIP's would give you an additional 50% or so in horsepower. Of course, doing this could get you dangerously close to tripping the 120A breaker while doing high speed pushing.
Team 1062, The Storm, 2003
Unread 04-02-2005, 00:34
MasonMM's Avatar
AKA: Mason Markee
well its a swerve/crab drive and only three of the wheel boxes are powered by chips. The forth wheel box just turns via the steering motor (separate from the drive motors) and drags along for the ride.
[ECDU]:drive train Michael Leicht FIRST-related Organizations 3 03-08-2004 16:23
To Maximum Oz and Two Train Joe Matt Thanks and/or Congrats 1 09-03-2003 13:03
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
