Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Unread 23-01-2005, 23:21
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Modifying CIMs to implode?
Originally Posted by tkwetzel
You could probably remove the paint easier with sand paper, if that was your goal.
Yes, but it wouldn't have that hot-off-the-lathe shiny look then.
Zan Hecht
Unread 23-01-2005, 23:22
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Has anyone tried any other modifications to help heat dissipation? Are there any places you can safely put holes in the casing to get some air flow inside?
Team 1257
Unread 24-01-2005, 00:05
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
The CIMs have a waterproof outer coat (black) by removing the coating it allows the motor to cool without the insulation of the hard rubber coating. Tyler Forbes on 190 was on my team for a number of years back in high school, and did battlebots for a number of years....a lot of people who used them turned them to save that fraction of weight, and allow for cooling....
Apparently since 190 did it...FIRST probably never had an issue...its that grey area we need to worry about...
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 24-01-2005, 11:29
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Hmm well I'll be waiting to see the reply to this question. I have been wondering about strapping some aluminum oil filter heatsinks onto the CIM motors for cooling. And turning it down or sanding off the paint would certainly help with thermal conductivity.
http://www.jcwhitney.com/autoparts/P.../p-298/c-10101
Between those and a 120mm fan by each transmission, that should help keep the CIMs cool
Unread 24-01-2005, 11:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by ConKbot of Doom
Hmm well I'll be waiting to see the reply to this question. On I have been wondering about strapping some aluminum oil filter heatsinks onto the CIM motors for cooling. And turning it down or sanding off the pain would certainly help with thermal conductivity.
That's a good idea, and better than nothing, but that mainly cools only the casing. The internals are still pretty hot, and by the time the casing is hot, they're VERY hot.
Still, like I said, any cooling is better than none
2001-2004: Team 100
2006-Present: Team 254
Unread 24-01-2005, 22:16
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
I'll defer to any thermal analysis guys, but doesn't a black body radiate heat more efficiently than a shiny aluminum surface?
Unread 24-01-2005, 22:22
Fold em oval!
I believe I have heard that black colored things generally radiate heat better, too, but there are much more important issues here. The paint-metal interface, and the paint itself probably conducts and radiates heat much worse than metal regardless of the color.
Team 1257
Unread 24-01-2005, 23:21
Contrary to intuition, shiny bare metal can often be closer to a "blackbody" than black paint. Some black paints are highly IR reflective, which generally means they are not that good at emitting IR when hot.
Unread 25-01-2005, 21:01
I think team update 5 sufficiently answered this question.
Unread 25-01-2005, 23:03
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Yeah, I think that makes it pretty clear: turning down motor housings to reduce weight => bad idea.
On a related topic, it is also a very bad idea to drill into the ends of the housings on the CIM motors, and through the permanent magnets, to open up a flow path to force air through the motors. This is considered a change to the "electrical system" of the motor (i.e. altering the magnets) and is a violation of <R31>. And to the teams that said "don't worry, the inspectors will never notice, and we will get away with it," you are wrong. The inspector-trainers have been alerted. I hear that the inspectors will be on the lookout for this - particularly at certain regional events.
-dave
Unread 26-01-2005, 08:10
For those who have not read the update (Why Not!?!)
<R31> So that every robot’s maximum power level is the same, the motors in the kit may
not be modified except as follows:
• It is acceptable to modify the mounting brackets and/or other structural parts
of the motors (output shaft, housing, etc.) as long as the electrical system is
not modified and the integral mechanical system of the moving parts
(bearings, bushings, worm gear output stages, etc.) is not changed or removed...
The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction by potentially compromising the structural integrity of any
motor.
As Dave pointed out above, drilling through the magnet to allow air flow violates this rule. Have you thought about what you are doing when you drill through a magnet? You are reducing the amount of magnetic material and therefore the field strength, thus reducing the output power of the motor. In addition, I have not yet seen a magnet that will drill without chipping which makes the reduction in field even worse. Occasionally, this type of abuse has been known to kill the field altogether.(vibration, chipping and cracking) You could drill through the case where there is no magnet but unlike the FP or drill motors, there is no internal fan to move the air.
BTW, I think I might be inspecting again this year and I will look for holes.
P.S. Can everyone quote the rule they are referring (from now on)to so we don't have to open a new browser window to see the reference?
Unread 26-01-2005, 13:02
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Less weight = less torque...
I strongly urge folks not to mess with the steel in the can of the Chiaphua (CIM) motor.
The metal thickness of the motor housing is part of the magnetic path of the motor. There are times when we actually ADD material around a motor to increase the torque of a motor (note the flux yoke on the Fisher Price motors). For some PSD motors, we can get about 15% more torque by simply putting a thick sleeve of steel around the outside of the motor can.
Reducing the motor can thickness on the CIM motor will almost certainly reduce the torque of the motor.
This is one of those happy cases where it is both illegal and bad engineering to remove metal.
Joe J.
P.S. as a rule of thumb, if a large paper clip can be picked up by using the outside of the motor can, it is likely that it could benefit from an external flux yoke, the stronger it sticks the more likely a benefit can be had.
Team #88, TJ2
Unread 26-01-2005, 13:17
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Originally Posted by dlavery
OK, so this question in the Q&A system has me intrigued:
The answer from FIRST has not been posted yet, but it has me wondering - is any team actually contemplating turning down the outer walls of the CIM housing? Does anyone expect to be able to remove any meaningful amount of weight without destroying the characteristics of the motor? This would seem to be a very bad idea in terms of maintaining the structural integrity of the motor, and a potential hazard. Or am I being overly conservative? Anyone have any thoughts about whether this should be/will be permitted?
-dave
The odd thing is that a teams has all ready done this. In fact this was the only arguement my friend had for saying this. I will ask him what team it is again though. I honestly feel it's a bit dumb but he said almost two pounds of weight can be lost. Anyway I feel it is a moot point because the question has been answered.
Unread 26-01-2005, 14:11
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
See this reply, in this thread: http://www.chiefdelphi.com/forums/sh...5&postcount=12
Two pounds?? As Ahecht pointed out in the above post, the weight loss was not very significant.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 28-01-2005, 01:12
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
I am not going to test the rule or disrespect the advice of motor techs on this list. My follow up is in regards to the reported gain in radiational cooling by removing the black paint by sanding to the bare metal?
Our team has never modified a motor or mount but the comment about bare metal verses paint is of mild interest. Does this violate the rule or even the spirit of the rule? I would guess that one could even add paint to the housing as part of some color scheme on the robot...
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
Modifying Default code great_one411 Programming 7 16-02-2004 10:32
where to buy cims Brawler006 Motors 2 26-01-2004 13:16
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
modifying sprockets gail OCCRA 3 05-10-2002 12:13
