Go to Post Pretty robots, who cares? Quality robots are another matter. - Steve W [more]
Unread 23-01-2005, 20:06
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Re: Skyway 4WD Help
Originally Posted by elknise
Oh, Thanks. On monday our team called IFI and they said that they were not planning on offering individual sprockets anytime soon.
For the sake of accuracy, IFI is now selling individual kit sprockets.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 23-01-2005, 20:47
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
Re: Skyway 4WD Help
our team is used 4 long bolt as a shaft, it fit nicly
Team 1009
Unread 24-01-2005, 00:28
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Skyway 4WD Help
Originally Posted by Cory
Any 3/8" diameter shoulder bolt with a shoulder the width of the wheel well should work fine.
Ya, but get it 5 in. long The chasis was made to fit that size bolt just right.
Unread 25-01-2005, 19:20
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
Re: Skyway 4WD Help
what about putting the axle onto the chassis? Do they sell a piece like the one diagramed (attached - sorry im not a good drawler)? Have you seen something like that before that we could buy instead of having to machine ourselves - we have limited resources?
Sorry if this was asked before.
Thanks.
Unread 25-01-2005, 21:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Skyway 4WD Help
Thanks.
That's called a pillow block. Search on MSC, McMaster, sdp-si, etc for them. They're easy to find, the trick is getting some that don't weigh 10 lbs.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-01-2005, 21:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Skyway 4WD Help
Go to page 1027 on http://www.mcmaster.com (just type the page in the search box). Scroll down a bit and you will see stamped base mount ball bearings. The are lighter than their cast iron coutnerparts. Also, pillow blocks are sometimes referred to as "mounted bearings"
Unread 25-01-2005, 23:00
Re: Skyway 4WD Help
AWESOME!!! Thanks for your help!!!
Is there any difference between the shaft sizes, because the 1/2", 5/8", 3/4" shaft sizes each say they support the 3/8" axles (bolts) we bought.
In addition, can we use the polyester (with delrin raceway) base-mount bearings instead of the steel ones? I would think it would be lighter, however under the circumstances, is the increased price X3 worth the added benefit?
ALSO - if we were to use 1/2" axles/bolts (our two front wheels are andymark omnidirectional wheels) would the same "pillow block" work for it? Should we get a different size? I ask this because the steel section doesn't say it supports a bolt hole size of 1/2", only stainless steel has a 1/2" bolt hole size option at 5x price though.
One other thing - say you needed 8 of these (2 for each wheel, right) are we talking a lot of weight here? If they were 10 pounds each that would be 80 pounds!!!
Any help answering these rookie questions would be greatly appreciated.
Skyway Wheel Hubs Nick R. Technical Discussion 2 10-01-2005 19:53
[OCCRA]: skyway wheels REPLY ASAP oaktown1188 OCCRA 3 04-10-2004 22:23
Need Skyway Tuffwheels Joshua May Kit & Additional Hardware 4 25-01-2004 01:31
Wheel Hub Connectors for Skyway Wheels Wayne C. Kit & Additional Hardware 16 10-01-2003 07:16
skyway -> hubs/sprockets crakmunkey Technical Discussion 1 21-01-2002 14:56
