Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 24-01-2005, 00:43
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Cool Having trouble with your camera mount?
Hey, i came up with an ingenius method of moving our camera around on two axes, after several days of unsuccessfully trying increasingly compicated and impractical solutions.
If you take apart a joystick ... (you probably can already see where i'm going with this), it has built in a nice little two-axis rotational system with the axes being read by potentioemeters. Well, with a little creativity and a Dremel and some superglue, I managed to successfully replace the potentiometers with servos.
They say that the difference between genius and insanity is measured only by success. Well I gotta say, this was incredibly successful.
I'll be taking some pictures for you all at my next meeting (tuesday)
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 24-01-2005, 00:47
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Having trouble with your camera mount?
I'd love to see this. We built our mount with EDU-Bot parts, as suggested in the CMU cam manual, but we aren't completely satisfied.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2005, 00:53
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
yeah, i saw those plans, but following the instructions just wouldn't be our style.
Unread 24-01-2005, 01:23
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
The guys on our team actually made a little box for the camera that had a hole and inside of the box, it looks like a little mini robot. The servo they have in the box, as I understand it, has tilt, and they're planning on using another servo to enable it to have pan. I dunno, I may be wrong. But it looks cool.
Unread 24-01-2005, 02:19
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I just stuck a tilt servo on the side of the edu bot mounting thing. Then took off the other side. Then took off everything else..... Basically its all new, and kind of flimsy, but it works for now.
Unread 26-01-2005, 22:22
sudeepr71 sudeepr71 is offline
FRC #0503 (Frog Force)
sudeepr71 is an unknown quantity at this point
Send a message via AIM to sudeepr71
Where does the tilt servo go on the mounting thing that they showed on the manuel? It tells how to put the pan, but not the tilt.
Unread 26-01-2005, 23:11
russell's Avatar
#1430 (WRONG)
Just play with it. I took a piece of the one square wide edu bot metal stuff and cut it so it was 1 square x 7 squares then bent it into a U shape with one square on the bottom and three on each side. Then I bolted one side of the U to the camera and the other to the servo head. Took like an hour and isnt very strong, and has all the weight on one side, but it sort of works.
Unread 01-02-2005, 22:12
114gopher's Avatar
114gopher 114gopher is offline
Co-Captain
AKA: Adam Garcia
FRC #0114 (Eagle Strike)
Team Role: Student
114gopher will become famous soon enough114gopher will become famous soon enough
Send a message via AIM to 114gopher
It is a great idea, and we would like to do something similar to the joystick mount system, but as one member pointed out, does it count as a pre-assembled part? Just wondering if there was anyone with thoughts on that matter.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
Camera Mount? AnkurG Electrical 3 14-01-2005 09:26
