Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 24-01-2005, 09:52
nwbutterfly nwbutterfly is offline
SparX
AKA: Nicole
#1126 (SparX)
nwbutterfly is an unknown quantity at this point
Send a message via AIM to nwbutterfly
Question Mating gear for the window motor?
Does anyone know what size gears is on the motor and where I could get a mating gear to put on a window motor? Any suggestions to how I can bolt a sprocket to the gear?
Unread 24-01-2005, 10:13
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Re: Mating gear for the window motor?
we had a lil fun with that last year... we took the sprocket assembly out of the motor, put a bolt through it, and then attached that to a drill press.. once that was going full speed, we took a grinder to it and ground down the sprocket small enough to fit the other sprocket onto it.. a lil bit of shade tree engineering, but it worked .. i wouldnt reccomend it though...
j
Unread 24-01-2005, 10:53
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Last year we removed the sprocket from the window motor, the guys in the machine truck at the Buckeye regional welded a thick washer to the teeth on the sprocket and we bolted a flat chain sprocket to the washer. drilled holes and tapped the washer and used 8 32 button head screws. Then put it all back together. Good luck.
Window motor mating gear Gui Cavalcanti Technical Discussion 5 24-01-2003 01:13
DP of Window Motor Gear? archiver 2001 9 23-06-2002 23:24
Black motor mating gear mnkysp6353 Motors 5 20-01-2002 11:09
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
