Go to Post Knowledge is power. Know whats coming and you can be ready for it when it happens. - KenWittlief [more]
Unread 24-01-2005, 16:07
MV_Hirsch MV_Hirsch is offline
MV_Hirsch is an unknown quantity at this point
Servos for the camera
Is there anything that you can call to figure out what the position of the servo is? What method would I call?
---Thankx
Unread 24-01-2005, 16:13
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Servos for the camera
There isn't a function or method to tell you the position of a servo.
This is an overview of how the servo works:
The software tells the robot controller to send the servo a position (0-254). Then the servo will try with all it's might to get to and stay at that position. There is never any feedback to the robot controller from the servo.
Unread 24-01-2005, 16:28
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
How do we know the orientation of the camera then?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 24-01-2005, 16:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
The camera is what is driving your servos, and it tells the RC where it thinks the servo is at. The actual variable used to relay this is described in the documentation for the camera. You can also find it in the source code of the default camera tracking code, particularly where it echoes the information back through the serial port by a printf.
Unread 24-01-2005, 16:35
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
I'm assuming you have the servos hooked up directly to the camera and are using the tracking feedback loop in the camera. In the default code in user_camera.c : camera_track_update() the RC gets some data back from the camera. Among this data is the pan & tilt positions (cam.pan_servo & cam.tilt_servo) of the servos. The pan position is used in user_routines.c : Camera_Processing() to make the robot turn left / right, and with a few more lines of code you can make the robot drive forward / backward based on the tilt.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Game Field Camera Calibration Matthew_H Regional Competitions 2 15-01-2005 23:09
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
