Go to Post I firmly believe that - those [GDC] committee members I have met, even briefly, certainly have a passion for what they are doing and want to give teams and students the best possible experiences. - GaryVoshol [more]
Unread 24-01-2005, 21:10
BookerT BookerT is offline
BookerT is an unknown quantity at this point
Error - symbol 'e' has multiple definitions. HELLPPPPP
This is the problem I have with compiling:
Make: The target "H:\FIRST\TEST\scripting_v1\main.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\user_routines_fast .o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\Program Files\Microchip\MPLAB ASM30 Suite\bin" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "H:\FIRST\TEST\scripting_v1\user_routines.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\ifi_utilities.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\ifi_startup.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\robot.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\encoder.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\gyro.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\pid.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\serial_ports.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\math.o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "math.c" -fo="math.o" /i"C:\Program Files\Microchip\MPLAB ASM30 Suite\bin" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "H:\FIRST\TEST\scripting_v1\printf.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\interrupts.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\PicSerialDrv.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\asm_lib.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\camera.o" is up to date.
Make: The target "H:\FIRST\TEST\scripting_v1\FrcCode.cof" is out of date.
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" /k"C:\Program Files\Microchip\MPASM Suite\LKR" "18f8520user.lkr" "H:\FIRST\TEST\scripting_v1\main.o" "H:\FIRST\TEST\scripting_v1\user_routines_fast .o" "H:\FIRST\TEST\scripting_v1\user_routines.o" "H:\FIRST\TEST\scripting_v1\ifi_utilities.o" "H:\FIRST\TEST\scripting_v1\ifi_startup.o" "H:\FIRST\TEST\scripting_v1\robot.o" "H:\FIRST\TEST\scripting_v1\encoder.o" "H:\FIRST\TEST\scripting_v1\gyro.o" "H:\FIRST\TEST\scripting_v1\pid.o" "H:\FIRST\TEST\scripting_v1\serial_ports.o" "H:\FIRST\TEST\scripting_v1\math.o" "H:\FIRST\TEST\scripting_v1\printf.o" "H:\FIRST\TEST\scripting_v1\interrupts.o" "H:\FIRST\TEST\scripting_v1\PicSerialDrv.o" "H:\FIRST\TEST\scripting_v1\asm_lib.o" "H:\FIRST\TEST\scripting_v1\camera.o" "H:\FIRST\TEST\scripting_v1\FRC_alltimers.lib" "H:\FIRST\TEST\scripting_v1\FRC_library.lib" /o"FrcCode.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Errors : 1
BUILD FAILED: Mon Jan 24 17:42:46 2005
Our "e" is defined in math.c
And is assigned as a "short long" array
Could that be the problem? Does normal "C" (Not C++) works with "short long"?
Unread 24-01-2005, 21:42
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Error - symbol 'e' has multiple definitions. HELLPPPPP
How large do you want the numbers to be? Short long, although it may be valid, sounds like an iffy type to use...
Try char/short/int/long instead.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 24-01-2005, 21:50
Electrical Engineer
Rookie Year: 1995
"short long" is just fine. Try changing the name of your variable "e" to "edward" and recompile. My guess is that "e" is used already somewhere else.
Mike Betts
As easy as 355/113...
Need for some official DEFINITIONS dhitchco Rules/Strategy 4 17-01-2005 15:59
Remember that thread? [11-11-04]: Multiple Regionals Ken Leung General Forum 5 11-11-2004 16:53
Multiple teams from one high school? KathieK General Forum 24 28-06-2004 16:30
Multiple Motors phrontist Motors 12 21-06-2004 23:05
