Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 24-01-2005, 22:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: reprogram during a competition
I would suggest a much simpler way of achieving the same results: optimize your code. It's free, and much less likely to malfunction. I truely doubt that you actually are going to run out of memory, but if you do, come up with creative ways of doing things. Use fewer variables. For example, if you were trying to swap two variables, instead of doing:
int c;
c=a;
a=b;
b=c;
...do:
a+=b;
b=a-b;
a-=b;
The first law of programming is that there are always ways of doing things quicker and in less space than you already are. (The ternary operator will be your friend in this pursuit.) Everyone is going to face the same problems that you are, and I doubt that anyone is going to absolutely need one of these devices. Good luck.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2005, 23:33
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
int c;
c=a;
a=b;
b=c;
...do:
a+=b;
b=a-b;
a-=b;
Ok now please bear with me, im a rookie programmer, but why would the above example save any memory space on the actual robot controller? when you build it, it just makes it assembly language (the .hex file), and both those (above) are the same. thats the whole goal.
in order to save memory, my team is using #define s for as much as possible, so when you compile/build it, as much as possible is already done. also, the same for some of the autonomous calculations--look up tables are faster and smaller than calculating something. (especially for trig functions, which you might need for autonomous--distance).
plz tell me if im horribly wrong or something...
thanks,
~Stephanie
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 25-01-2005, 02:05
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
If you need a sufficiently small number of values, table lookup will
save space. It just depends on how many you need. In the general
case, an algorithm will save space and table lookup will optimize for speed.
The use of #define will not necessarily save space (except in your
source files, where you don't care). It depends on how you are doing things.
To save space with constants, you want every reference to the value of the
constant to be to the same memory location. If you just use the define, you
will be storing the constant value everywhere it is used.
Unread 25-01-2005, 02:17
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I might be totally missing something, but like jgannon says it takes (me at least) way more than 1.5 seconds to download a program to the RC. More like 1.5 minutes. And why dont you simply do the processing on something else (how much does a 386 cost?) and just use the RC for I/O?
Unread 25-01-2005, 05:11
Electrical Engineer
Rookie Year: 1995
Jacob,
At the risk of sounding condescending, I can't believe that anyone is running out of space. If so, take a good hard look at what you are doing.
Programming an embedded system is absolutely nothing like programming a PC.
First rule: Never, never, ever use floating point arithmetic.
Second rule: Never, ever use dynamic allocation of memory.
Third: Avoid pointer manipulations unless you understand what it does in the machine (some dereferencing manipulations are murder).
Look at the assembly code being generated by the compiler. You can see it in the .lst file that is generated when you build your project.
Good Luck,
Mike Betts
As easy as 355/113...
Unread 25-01-2005, 09:11
Significant processing between operator input and motor action.
Navigation (and all the trigonometry it requires).
Multiple independently-tuned PID controls.
Adaptive autonomy.
Finally, lots and lots of text for communicating with the camera.
I can easily understand someone running out of space. Last year's robot only did about half of what we have planned for this year, and it's using about 65 percent of the space.
Unread 25-01-2005, 10:11
I have to agree with Alan that if you try to dump everything possible this year into the program it can grow large.
Maybe not what you are looking for, but have you tried using the built-in compiler optimization to reduce your program bulk?
In MPLAB
  • Project -> Build Options... -> Project
  • MPLAB C18 tab
  • pulldown categories and select Optimization
  • click "enable all"
I tend not to use the compiler optimization unless necessary, because we've all had problems with optmizers in the past. Just test afterwards to make sure everything is working properly.
You have gotten rid of the IFI printf code, right?
Unread 25-01-2005, 10:58
With all the text strings and all the interrupts and associated volatile variables floating around in this year's code, I wouldn't expect a whole lot of extra optimization. It's my guess that most "reduced bulk" will still have to come from effective algorithms and efficient implementations rather than compiler tricks.
Fortunately, I have something of a knack for efficient implementations.
Unread 25-01-2005, 11:23
Made me look.
The default FRC 2.4 version of the code comes in at 18,927 bytes or 55%.
Optimizing gets you down to 14,743 bytes or 43%
Sorry for the thread hijack Jacob. Us old folks tend to ramble on sometimes.
I don't know of any rule that prohibits the downloading of new code as long as it's occurring within the custom circuit rules, and I can't think of any harm that might do from a safety or IFI control perspective.
P.S. My wife was a warhawk. Just had a reunion in Vienna this past summer.
Unread 25-01-2005, 12:02
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Can you explain this one a little more? I'm used to UNIX programming where I never have to worry about this being a problem, so we used pointers quite a bit last year and plan on the same this year.
Originally Posted by Ryan Foley
He brings up a very good point. I believe that in 2003 the Wildstang 111 robot had a Motorola processor on it to do all of the calculations and processing, and the RC itself would be used for only a little bit of the program and the I/O. Go to the Wildstang website and click on "Stang PS" for a bit more information.
You've very close. In 2003 & 2004 the Custom Circuit kept track of our position on the field and every loop of autonomous the RC would ask the CC for the robot's position & heading. Then the RC would determine the path to get to the target, do the driving & arm moving, and recognize when we got to our target. The presentation on our site doesn't show the interface between the RC & CC. For this year we're planning to offload almost all of the positioning & guidance to the CC and have the RC focus on determining what to do based on the strategy, and vision tetra positions.
Unread 25-01-2005, 14:47
russell's Avatar
#1430 (WRONG)
How do you guys connect the RC and the CC? If you used the ttl port then you are going to have to (actually you probably already did) find a way to hook two things to it at once assuming you are using the camera.
Back on topic however, It seems to be legal to reprogram in a match, but you might have a lot of explaining to do. The thing that will worry the judges the most is the possibility of you screwing with their master code. I would stay away from it for this reason, not to mention all of the reasons already mentioned. You are asking for trouble with both the technical and "legal" aspects of it, when it seems like you could accomplish something the same or better more easily, without the concerns over the rules. Thats just what I think.
Unread 25-01-2005, 15:06
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
thanks for the answer
as for
serial communication is over digital IO lines. you can copy IFIs buffers, or write your own. you end up with 16 some odd serial ports (of course, you need to make your own connectors)
the chip by itself runs TTL levels (+5v) for the signal. with serial comunication, most things will cope just fine with +5, (rs232 spec goes to +15v, but we would use +12v), but some things are just pickey. so if you want to be "fully" compatable with all devices, your going to need a RS232 converter chip. any electrionics provider will sell them... you can get 4 converters in one IC for a buck or two
"You're not a real programmer until all your sentences end with semicolons;"
Unread 25-01-2005, 15:30
If you are going to have another processor on your robot to do the programming, why not use that processor to offload some of the work?
You also need to check with IFI. I wouldn't be suprised if the field controllers freak out while the User processor is being programmed.
Unread 25-01-2005, 18:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I ran out of space with just the default code with the scripting and camera code early in the season. There were virtually no modifications to the code except to put the 2 together, which was extremely little.
The way I solved this was to just enable more obtimizations. If you do advanced debuging, read the compiler manual first. A few of them change break points, which I presume apply to the simulator, too.
Unread 25-01-2005, 08:33
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
CMUcam II and competition lighting environments dlavery Programming 5 16-02-2005 02:07
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
