Go to Post FIRST involves school, parents, family etc etc....at least it does at our house! - MrForbes [more]
Unread 24-01-2005, 21:56
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
reprogram during a competition
At the risk of poking at a delicate subject – could the robot legally reprogram itself during a competition?
With a normal match the UI and the RC are in constant communication, but until the 15 sec autonomous mode is up, none of the joystick inputs (read – any input that operators can control) are active. As we have covered in other threads, a switch set before the match started could be detected by the robot before the controls were nulled. However it is blatantly wrong to have the robot be reprogram itself based on, say, at the location of the vision tetras: although theoretically possible with a 16F84, a flash card, and some clever coding and a 6 way switch.
My question pertains to reprogramming of the robot, by the robot, at the end of the 15 second autonomous period. My team has had problems with limited memory of the PIC, and with camera tracking and accelerometer algorithms we are close to the maximum size, without any of the operator-assist code.
Consider this example: When the 15 seconds of self control time is up, the autonomous flag is cleared; the RC pulls a digital output high. A carefully programmed microcontroller would emulate the serial port of a PC, putting the RC into boot loader mode and handing it the second set of code from an external EEPROM or “flash drive”. After the 1.5 or so seconds that the process takes, the robot is reset with its new code and on its way for the 2 minutes of user control.
anyone have any comments? does this violates any FIRST rules?
Thanks – jsd
"You're not a real programmer until all your sentences end with semicolons;"
Unread 24-01-2005, 22:00
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: reprogram during a competition
I am not a programmer but could you explain why you would need to do that after Auto mode is over the robot is in driver mode and the only programing that you would need is what is need to run from the controller to the robot, right?
Just remember that i am not a programmer, I would just like to know why that would be needed. so please be nice if I sound really dumb.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 24-01-2005, 22:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I would suggest a much simpler way of achieving the same results: optimize your code. It's free, and much less likely to malfunction. I truely doubt that you actually are going to run out of memory, but if you do, come up with creative ways of doing things. Use fewer variables. For example, if you were trying to swap two variables, instead of doing:
int c;
c=a;
a=b;
b=c;
...do:
a+=b;
b=a-b;
a-=b;
The first law of programming is that there are always ways of doing things quicker and in less space than you already are. (The ternary operator will be your friend in this pursuit.) Everyone is going to face the same problems that you are, and I doubt that anyone is going to absolutely need one of these devices. Good luck.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-01-2005, 22:16
AKA: theshadow
FRC #0620 (WarBots)
I think what you’re trying to say that the driver code is not complex, or long, because it just takes the values from the joystick and sends them to the Victors.
Our driver code is both complex and long, and we go over it hours at a time trying to make it shorter, and it’s still huge. We use sensors to measure rotation and two direction acceleration, and make changes to the motor outputs based on where the robot is and where the operator wants the robot to be. And all of the arm controls, limits, etc take up space too.
The memory on the RC is limited to start with (a couple of KB). It doesn’t help that the chip was designed to run assembly and we compile C++ to it… C is a complicated high level language that uses lots of libraries that take space. Then IFs “default” code is a beast (its got to be compatible with every team), but you cant ditch it because they wont give you total control over the RC (it’s a boot loader, ugg). And some of our programming team members write crummy code. All and all, memory is precious, and the more the better.
I hope this answers your question, jsd
Originally Posted by jgannon
I would suggest a much simpler way of achieving the same results: optimize your code. It's free, and much less likely to malfunction. I truely doubt that you actually are going to run out of memory.
We work only on code every day for 6 weeks… we can do 80% of stuff with out a second program
I’m sorry if you doubt it, but I have run out of memory, and its not fun. Actually the first time it happened was in the pits, but I was writing sloppy code, so it is expected.
Incase it wasn’t clear -- This was a theoretical question; the probability that I would implement it is very low. But when my team comes up with another page of stuff the robot is suppose to do by itself; I at least need a worst case scenario
Thanks though – jsd
Unread 24-01-2005, 22:20
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I believe your effort would be much better spent optimizing your code to make it smaller as others suggested. There is a lot you can legally and safely strip out of the default code. Additionally, once you have your code debugged and in a stable stage, you can start rewriting stuff to sacrifice manageability and "good" programming practice for smaller size.
BTW, we are programming in C, not C++ and every robots code that I have seen uses very few extra libraries.
Team 1257
Unread 24-01-2005, 22:31
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Bah, and here I tried to provide a practical answer.
Look at the Additional Parts flowchart in section 5 of the manual to determine if this device is legal or not. If you don't get a satisfactory answer, try the FIRST Q&A.
One more note on the practicality of this: maybe our programming computer is different from yours (1.8GHz seems like enough), but it takes a bit longer than 1.5 seconds for me to send code to the RC with IFI Loader.
_
Unread 24-01-2005, 23:33
RbtGal1351's Avatar
RbtGal1351 RbtGal1351 is offline
~La Reina de los Robots~
AKA: Stephanie
FRC #1351 (TKO)
RbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to beholdRbtGal1351 is a splendid one to behold
Send a message via AIM to RbtGal1351 Send a message via MSN to RbtGal1351
int c;
c=a;
a=b;
b=c;
...do:
a+=b;
b=a-b;
a-=b;
Ok now please bear with me, im a rookie programmer, but why would the above example save any memory space on the actual robot controller? when you build it, it just makes it assembly language (the .hex file), and both those (above) are the same. thats the whole goal.
in order to save memory, my team is using #define s for as much as possible, so when you compile/build it, as much as possible is already done. also, the same for some of the autonomous calculations--look up tables are faster and smaller than calculating something. (especially for trig functions, which you might need for autonomous--distance).
plz tell me if im horribly wrong or something...
thanks,
~Stephanie
2004 Founding member and Arm leader, 2005 Lead programmer, 2006 Controls leader, 2007 Project Manager/President
Thanks for making FIRST such a great experience for me. I'm no longer on 1351, and I'm not currently planning to mentor team 97, but FIRST has meant so much in getting me to where I am now, in life and at MIT, class of 2011.
I met Billfred! He recognized me!
SVR 04: 11th seed - Highest Rookie Seed - Semifinalists w/ 1120 and 568 - GM Industrial Design Award
SVR 05: Semifinalists w/ 8 and 766
SVR 06: 6th seed - Quarterfinalists w/ 368 and 1072
Davis 06: 1st seed - Quarterfinalists w/ 649 and 100 - KPCB Entrepreneurship Award
SVR 07: 36th seed
David 07: 4th seed - Semifinalists w/ 1280 and 692 - Johnson and Johnson Sportsmanship Award
Unread 25-01-2005, 02:05
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
If you need a sufficiently small number of values, table lookup will
save space. It just depends on how many you need. In the general
case, an algorithm will save space and table lookup will optimize for speed.
The use of #define will not necessarily save space (except in your
source files, where you don't care). It depends on how you are doing things.
To save space with constants, you want every reference to the value of the
constant to be to the same memory location. If you just use the define, you
will be storing the constant value everywhere it is used.
Unread 25-01-2005, 02:17
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I might be totally missing something, but like jgannon says it takes (me at least) way more than 1.5 seconds to download a program to the RC. More like 1.5 minutes. And why dont you simply do the processing on something else (how much does a 386 cost?) and just use the RC for I/O?
Unread 25-01-2005, 05:11
Electrical Engineer
Rookie Year: 1995
Jacob,
At the risk of sounding condescending, I can't believe that anyone is running out of space. If so, take a good hard look at what you are doing.
Programming an embedded system is absolutely nothing like programming a PC.
First rule: Never, never, ever use floating point arithmetic.
Second rule: Never, ever use dynamic allocation of memory.
Third: Avoid pointer manipulations unless you understand what it does in the machine (some dereferencing manipulations are murder).
Look at the assembly code being generated by the compiler. You can see it in the .lst file that is generated when you build your project.
Good Luck,
Mike Betts
As easy as 355/113...
Unread 25-01-2005, 08:33
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
He brings up a very good point. I believe that in 2003 the Wildstang 111 robot had a Motorola processor on it to do all of the calculations and processing, and the RC itself would be used for only a little bit of the program and the I/O. Go to the Wildstang website and click on "Stang PS" for a bit more information.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 25-01-2005, 09:11
Significant processing between operator input and motor action.
Navigation (and all the trigonometry it requires).
Multiple independently-tuned PID controls.
Adaptive autonomy.
Finally, lots and lots of text for communicating with the camera.
I can easily understand someone running out of space. Last year's robot only did about half of what we have planned for this year, and it's using about 65 percent of the space.
Unread 25-01-2005, 10:11
I have to agree with Alan that if you try to dump everything possible this year into the program it can grow large.
Maybe not what you are looking for, but have you tried using the built-in compiler optimization to reduce your program bulk?
In MPLAB
  • Project -> Build Options... -> Project
  • MPLAB C18 tab
  • pulldown categories and select Optimization
  • click "enable all"
I tend not to use the compiler optimization unless necessary, because we've all had problems with optmizers in the past. Just test afterwards to make sure everything is working properly.
You have gotten rid of the IFI printf code, right?
Unread 25-01-2005, 10:22
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
There are only about 1300 bytes (1200? I forget the exact number.) of variable space available to the user. My first example requires three ints, for a total of six bytes. The second example requires two ints, for a total of four bytes. I understand that variable allocation is not the only concern with respect to memory, but teams will discover that if they start wildly instantiating global variables, they'll start getting a lot of weird compiler errors, indicating that they've run out of space.
Faster, maybe, but definitely not smaller. I've been seeing all of these lookup tables that teams are using for desensitizing their joysticks, when all they really need is a simple quadratic equation, which I'm certain will take up significantly less space on the bot.
Hm... no I haven't. I didn't even know that existed. That may very well come in handy for all of us. Thanks.
_
Unread 25-01-2005, 10:57
AKA: theshadow
FRC #0620 (WarBots)
im sorry if you misunderstood my question. i was wondering if reprograming the robot was legal durring the compitition.
again, thanks -- ive been programming MCUs since i was 9 and got my first BOE-BOT kit... 7 years later i think i can tell the difference between a IBM platform PC and a PIC microprocessor
i don’t like the thought of using chars, ints are pushing it...
external EEPROM is better then internal memory if you want to map data, but i generally use algorithms anyway (DMA isnt my cup of tea)
this i most hardly agree with
I used to write assembly for fun, thank you very much - thus my habits of not using as few IFs as possible; i much prefer boolean algebra.
Im not a "newbie" programmer, ive have been the head of our programming team since my freshman year. I have taken collage level CS in JAVA and C, as well as many, many courses on programming in just about every other modern high level language.
However, i have been doing this for a relatively short period of time -- there are people that are much better at this then i will ever be, and many of them participate in FIRST. i never pretend to know everything, so i respect everyone on the forums, and assume they know more then me, and in turn I hope they respect me
also i try very hard to keep delphi threads to the point... but stuff like
is unnecessary. i am sorry that you dont believe me , i never thought that i would have to take a screnie for something like that.
external processing is what our team has planned thus far. and i will be sure to try Marks optimization process... i wasnt looking for a lecture on how to optimize code (read the thread title!) i was looking for the legal implications of reprogramming the robot during a match. Thanks anyway – jsd
CMUcam II and competition lighting environments dlavery Programming 5 16-02-2005 02:07
2004 WPI EBOT Competition (using Robovation robots) ahecht Off-Season Events 3 04-11-2004 21:25
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
