Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 25-01-2005, 00:07
Alex Wijtowych Alex Wijtowych is offline
Alex Wijtowych is on a distinguished road
Array Problems: Possible<stdio.h>
Hello, I would appreciate if anyone can help me out with this arrray statement. I'm not sure if I have to put it in a function or import a header library so I can use an array. Here is my code, also it is available to anyone who wants to use it. It uses one joystick to drive a a 2 wheel drive bot with the wheels in the centre, like a tank. It also solves the problem of having the joystick go forward and the bot turn and vice versa.
/*Alex Wijtowych's Little addition to the code to make a dual axis drive system with a smoother control!!!*/
/*Let PWM 09 represent the right wheel of the bot and PWM 10 represent the left wheel of the bot*/
int speed_array[255] ={0,0,0,0,0,0,0,4,8,12,16,20,23,27,30,34,37,40,43, 45,
48,51,53,56,58,60,63,65,67,69,71,73,75,76,78,80,81 ,83,84,86,87,88,90,91,
92,93,94,96,97,98,99,100,100,101,102,103,104,105,1 05,106,107,107,108,
109,109,110,111,111,112,112,113,113,114,114,114,11 5,115,116,116,116,
117,117,117,118,118,118,119,119,119,119,120,120,12 0,120,121,121,121,
121,121,122,122,122,122,122,122,123,123,123,123,12 3,123,123,124,124,
124,124,124,127,127,127,127,127,127,127,127,127,12 7,127,127,127,127,
127,127,127,127,127,127,127,130,130,130,130,130,13 1,131,131,131,131,
131,131,132,132,132,132,132,132,133,133,133,133,13 3,134,134,134,134,
135,135,135,135,136,136,136,137,137,137,138,138,13 8,139,139,140,140,
140,141,141,142,142,143,143,144,145,145,146,147,14 7,148,149,149,150,
151,152,153,154,154,155,156,157,158,160,161,162,16 3,164,166,167,168,
170,171,173,174,176,178,179,181,183,185,187,189,19 1,194,196,198,201,
203,206,209,211,214,217,220,224,227,231,234,238,24 2,246,250,254,255,
255,255,255,255,255,255};
if (p1_y > 127 )
if (p1_x > 127)
pwm09 = speed_array[255 - (2 *(p1_x - 127))];
pwm10 = speed_array[p1_y];
else if (p1_x < 127)
pwm09 = speed_array[255 - p1_y];
pwm10 = speed_array[255 - (2 *(127 - p1_x))];
else if (p1_x == 127)
pwm09 = speed_array[p1_y - 127];
else if (p1_y < 127)
if (p1_x > 127)
pwm10 = speed_array[2 *(127 - p1_x)];
pwm09 = speed_array[127 + (127 - p1_y)];
else if (p1_y == 127)
if (p1_x < 127)
pwm09 = speed_array[127 + (127 - p1_x)];
pwm10 = speed_array[p1_x];
else if (p1_x > 127)
pwm09 = speed_array[127 - (p1_x - 127)];
pwm09 = 127;
pwm10 = 127;
Unread 25-01-2005, 01:08
Electrical Engineer
Rookie Year: 1995
Re: Array Problems: Possible<stdio.h>
You may want to consider making your array a "rom const".
Mike Betts
As easy as 355/113...
Unread 25-01-2005, 09:04
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
You don't need to include anything or do anything special to use an array. It's just a variable like anything else.
Matt
Unread 25-01-2005, 12:01
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I had to change two things to make your code compile. First, I changed the array dimension to 256, since you have 256 initializer values. (Remember the range from 0 to 255 contains 256 values.)
I also had to change the array definition from "int speed_array" to "rom const int speed_array" as Mike suggested. Without the "rom const", the linker complained: "Error - section '.idata_user_routines.o' can not fit the section. Section '.idata_user_routines.o' length=0x00000208".
It would probably be possible to edit the .LKR file to make the data fit without making it "rom const", but this way is easier. There's no reason to sweat making data fit into RAM when the program will never change it.
Unread 25-01-2005, 13:50
Ssbfalcon's Avatar
Ssbfalcon Ssbfalcon is offline
The beta version
AKA: Arthur
FRC #1546 (Chaos Inc.)
Ssbfalcon is an unknown quantity at this point
Send a message via AIM to Ssbfalcon
Personally I would have come up with a formula to automate this for you.
Either way, you shouldn't use an integer array as the values range from 0-255. Because of that, all you need are unsigned chars, which range from 0 to 255.
Just incase you're unsure of the syntax...
 unsigned char speed_array[255] ={0,0, ... 255};
Ints normally use 2 bytes, while chars use 1 byte. The integer array of 256 would be 512 bytes while the char array only 256 bytes. That's one method of code optimization that you should look out for. It's easy to just write ints for everything, when all that's required is a char whether it's signed or unsigned. Remember that the system we're coding under has limited resources, and little things like these can mean cutting off an extra feature.
Still, if we had some more resources...
Don't Lick Dry Ice!
Unread 25-01-2005, 18:26
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If a look-up table is semetric (meaning the values below 127 are just as low as the values above are high), then you can cut the table size in half.
Here's my code for it:
const rom signed char JOYSTICK_SMOOTHING[128] =
0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 2, 2,
2, 2, 3, 3, 3, 3, 4, 4, 5, 5, 5, 6, 6, 7, 7, 8,
8, 9, 9, 10, 10, 11, 11, 12, 13, 13, 14, 14, 15, 16, 17, 17,
18, 19, 20, 20, 21, 22, 23, 24, 25, 25, 26, 27, 28, 29, 30, 31,
32, 33, 34, 35, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 48, 49,
50, 51, 53, 54, 55, 56, 58, 59, 61, 62, 63, 65, 66, 68, 69, 71,
72, 74, 75, 77, 78, 80, 81, 83, 85, 86, 88, 89, 91, 93, 95, 96,
98, 100, 102, 103, 105, 107, 109, 111, 113, 114, 116, 118, 120, 122, 124, 126
void Drive_Joystick(char Left, char Right)
	if(Left > 127)
		Left_CIM = Left_Drill =  (128 + JOYSTICK_SMOOTHING[Left - 127]);
	else
		Left_CIM = Left_Drill = (127 - JOYSTICK_SMOOTHING[127 - Left]);
//	Right_CIM = Right_Drill = Right;
   	if(Right > 127)
		Right_CIM = Right_Drill =  (128 + JOYSTICK_SMOOTHING[Right - 127]);
	else
		Right_CIM = Right_Drill = (127 - JOYSTICK_SMOOTHING[127 - Right]);
Note: Each side had 2 motors which always had to be the same value. They were named CIM and Drill (guess what kind they were). So Left_CIM and Left_Drill were the left-side motors and Right_CIM and Right_Drill were the right-side motors.
This could be reduced to a macro:
#define SMOOTHED_VALUE(joy) ( (128 + JOYSTICK_SMOOTHING[(((joy)>127) ? ((joy) - 127) : (127 - (joy)))]) )
(Macros are kinda like Perl one-liners: only the author really knows what's going on.)
Unread 25-01-2005, 23:14
Chris Bright's Avatar
Chris Bright Chris Bright is offline
#1023 (Bedford Express)
Team Role: Webmaster
Chris Bright will become famous soon enough
Send a message via AIM to Chris Bright
When the array is stored in the ROM does that mean the array has to be global? I had a smoothing function last year but i just called the array like so: motor1 = smooth[joy]; However, this year i wanted to put it in function and i kept getting errors saying the stack size was too large. I have a feeling this is due to a variable's scope in a function. Could i use static to place the variables in a function?
2003 - National Rookie All-stars
2003 - Great Lake Rookie All -stars
Unread 26-01-2005, 04:39
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
No, it doesn't have to be global. If it's outside a function, it will have global scope by default. But you can restrict its visibility to the file only by assigning it "static" storage class. You can also hide the array inside a function. It compiled cleanly when I defined it as "static rom const unsigned char speed_array[256]..." inside a function. (Thank you Arthur(Ssbfalcon) for pointing out that all the data values in the array would fit in char sized elements.)
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
