Re: Globe motor mounting
Last year, my ascending system used two globe motors. I did what you want to do, I bored the two ends of the main drum with the shape of the output shaft, the motor just slid in, and that was it, no set screws to worry about. It was however, a pain in the butt to mill by hand (which is what I did) - but it is possible. Of course, if you could, and the design permits (mine did not) you could always use wire EDM, or water jet like the above person mentioned, also do not forget about CNC milling, as it would have worked for what I needed it to if we had a CNC mill large enough. I think using the technique you used in the past was good in a pinch, but I would constantly be worried about the set screws. Globe motors rock, and I had two, because everyone was afraid to use them (no side loads are tolerable) - so remember that!! don't just cantilever the gear without proper shaft support, or you will eat the gearhead in a second! Good luck with your project.
We have used the globe motors for several different applications.
We had a square hole EDM'ed out of the center of a sprocket than had a square block made that fit the square hole and the oval shaft of the globe motor. It was sweet. Very precise EDM'ing. Wayne Doenges CAD Mentor |
We use globe motors on our satellite dish feed assy. In order to insure that there is no slipping of the gear, a small hole is drilled through the gear and motor output shaft and a drill rod (drill blank) or roll pin is inserted to hold the two together.
| 2 Globe Motors??? | ChuckDickerson | Motors | 18 | 25-01-2005 15:53 |
| Globe motor backdrive!! | Srkasner | Motors | 19 | 08-03-2004 00:10 |
| Globe Motor | archiver | 2000 | 4 | 24-06-2002 00:15 |
| So you want to stall a Globe Motor... | archiver | 2000 | 1 | 24-06-2002 00:09 |
| Globe Motors & other FIRST Suppliers at Design Show | archiver | 1999 | 2 | 23-06-2002 22:07 |
