Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 25-01-2005, 17:59
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
kit bot wireing
We are trying to wire the kit bot, and we need to know what motor goes to what pwm output on the rc? Also what ports to hook up the joy sticks to. Or better yet a detailed document that tells us how to wire the kit bot in its default configuration. We have the power cables wired, but we can't seem to get the motors to run when we move the joysticks. If we hook up the victors to outputs 1 and 3 the motors will run constantly, but the joysticks have no control over them. Please help a team that can't even drive their bot.
our web site
sphere bot Veselin Kolev Technical Discussion 36 03-03-2005 00:03
VIDEO the kit bot - programmers test mtaylor Robot Showcase 6 09-02-2005 01:15
Coding CDs in the kit -- What'd you get? elyscape Programming 1 08-01-2005 14:31
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
