Re: Need help designing keyway in gear
If you clamp the gear on like that (incidentally, www.sdp-si.com sells stock gears with that type of hub for clamping), that may very well transfer enough torque. It will definitley be pretty hard to analyze the amount of torque it should transfer (though I'm sure the clamp and they keyway would be plenty), so you may not feel comfortable with it, but its just another thing to consider.
| gears | Michael Leicht | Inventor | 12 | 16-09-2004 10:52 |
| Reverse Gear | FizMan | Technical Discussion | 12 | 26-04-2004 01:29 |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
