Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 20-01-2005, 12:13
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Four wheel drive question
Originally Posted by JVN
That's affirmative.
With the "ROBOT-SPROCKETS-2005" Kit ($80 + shipping) you can construct the 4WD configuration I show on the right in my above post.
Isn't that awesome?
Less than $100 for a fully working 4-motor, 4WD base.
It's a brave new world.
JV
You will also need the wheel adapters or make your own. IFI is currently out of stock. I was planning on making four plates and using only one wheel adapter per wheel. The plate would go on the opposite side from the sprocket. There are drawings for wheel adapters on the FIRST CAD library.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 20-01-2005, 19:32
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
I saw this FAQ on the IFIrobotics.com Site...
So, we also need the sold out hubs? Does this mean we also need an additional chain OTHER than the one included. Also, the sprockets listed below - those are IN ADDITION to the ones already in the kit (all four of them?), correct?
Sorry if this is a stupid question...
Thanks,
Jason
"What do we need and how do we make a four wheel drive system out of what we have in the kit?
Please check section 3 in the "2005 FIRST Robotics Competition Kit Transmission Manual -RevA" document located at http://www.ifirobotics.com/kitbot.shtml.
You do not need the custom PVC spacer used in the 2 wheel drive configuration and you need to use the 40mm key provided in the kit instead of the 20mm key. You also need additional parts to make the 4 wheel drive configuration. The additional parts you need are:
1. 21 tooth sprocket - Quantity 2. Available from ifirobotics.com
2. 28 tooth sprocket - Quantity 2. Available from ifirobotics.com
3. Skyway wheel hubs - Quantity 2 sets.
4. 10' of chain. Available from ifirobotics.com"
Unread 20-01-2005, 21:44
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Kit Bot Parts
I just found out yesterday that IFI now sells individual sprockets of both kinds for 19.99$
Elknise
Issaquah Robotics
Unread 21-01-2005, 10:46
Originally Posted by elknise
Kit Bot Parts
Yes, but according to that FAQ it seems that we need 2 of BOTH anyway? Is that true?
Unread 21-01-2005, 11:38
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Well, you should need a total of 4 big sprockets, one for each wheel, and a total of 4 small sprockets, 2 on each geabox output. Then you will put 4 separate chains, one to each wheel. You could run with only 1 sprocket on each output and use one longer chain to turn both wheels on that side but I'd advise against it. You would need to make a semi elaborate idler system to get an adequate (more that 150°) of chain wrap on the drive sprocket.
Unread 21-01-2005, 12:09
President, VEX Robotics, Inc.
In either case, you need more than just the wheel sprockets. For the 4 chain option (two per transmission) as documented in the kit you need four output sprockets (two per transmission). For the two chain option (one per transmission), you will need at least one idler per side.
Bottom line, for four wheel drive you need more hardware than just two more wheel sprockets. That is why IFI packaged the sprockets together.
-Paul
Unread 25-01-2005, 13:10
BlazinFire47's Avatar
BlazinFire47 BlazinFire47 is offline
Alumni
AKA: Blaze/Blackmoon/Nova
FRC #0047 (Chief Delphi)
BlazinFire47 is on a distinguished road
Send a message via AIM to BlazinFire47 Send a message via MSN to BlazinFire47 Send a message via Yahoo to BlazinFire47
well.... you can forsay create your own 4-wheel drive system you know.... but it does involve lots of build time and 3 weeks have passed now.... to keep it sweet and simple.... 4-wheel drive will not a big issue this year.... i forsee that most teams will be using 2 wheel drive or swerve.... so if it is easier right now use 2- wheel drive for the timeframe we have right now...
Unread 25-01-2005, 22:10
csquared05 csquared05 is offline
#1005 (Csquared Robotics)
csquared05 is an unknown quantity at this point
Send a message via AIM to csquared05
last year we used 4 wheel drive, but it was extremely jumpy on the carpet last year when we were turning with the supplied wheels. We improved our control by using zip ties, but they weren't 100% effective. How have other teams overcome this jerkiness?
Unread 25-01-2005, 23:13
A TechnoKat robot from a few years ago used a pneumatic "puck" that lifted the front end of the robot when the joysticks were calling for a turn. This was on a tank-tread drivebase rather than a four-wheel drive, but the idea works either way.
If you aren't dead set on the supplied wheels, you have many options, including omniwheels. The 2004 KatsKlaw just used extremely grippy rear tires and enough motor power to make the front wheels slip without too much skipping.
Unread 25-01-2005, 23:15
What are your thoughts on using the supplied wheels as the power (attached to the motors) with omniwheels as the front wheels? This way there would be no drag on the front tires it would go freely either direction?
Unread 25-01-2005, 23:24
Indeed, that's exactly how we have built the kitbot for testing purposes this year. Though the omniwheels aren't really designed to be freewheeling, it works. It seems to give a little more of a bumpy ride than I would have expected, but that might just be due to the lightness of the front end of the chassis.
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
XP Hard Drive Space Question Raven_Writer Chit-Chat 13 07-08-2003 16:38
