Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 23-01-2005, 19:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
LCD wiring to Program port
I am in the process of wiring up a BPP-420 LCD to the Program port on our RC for use with Kevin Watson's serial port code. I have pin 3 of the serial connector connected to the data pin on the LCD, I have the +5 pin from a digital I/O connected to the +5 pin on the LCD, and I have pin 5 and the ground from a digital I/O connected to the ground pin on the LCD. Is this the proper wiring? I couldn't find an actual pinout of the Program port, so I just went with the RS-232 standard, but I want to make sure it's right before I power it up.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-01-2005, 19:39
Electrical Engineer
Rookie Year: 1995
Re: LCD wiring to Program port
Refer to page 11 of "2004 Full-Size Robot Controller Reference Guide".
If I call +5V pin 1, then pin 1 goes to +5 of the LCD, Pin 2 goes to data in of the LCD and pin 4 goes to ground on the LCD.
Mike Betts
As easy as 355/113...
Unread 23-01-2005, 19:52
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
That's the TTL port, not the Program port. My LCD only works on RS-232 voltage levels, and besides, I'm already using the TTL port for the camera.
_
Unread 25-01-2005, 12:08
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Did you get this working? I've wired my LCD to use pin 2 as it's source of serial data.
-Kevin
Kevin Watson
http://kevin.org
Unread 25-01-2005, 23:37
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
-Kevin
I haven't tested it yet, because I'm particularly afraid of the magic smoke when working with something this expensive. I will move the data line over to pin 2. Do I have the other wiring correct?
_
Unread 25-01-2005, 23:47
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Someone just told me in another thread that RS-232 is does 5 to 15 volts. Dont see how that is going to help you, but it might and I dont feel like thinking too much. Actually I think it was that thread about reprogramming in competition.
Unread 25-01-2005, 23:55
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
*shrug* The specs make no difference to me. My LCD needs +5 for power, and RS-232 level data. I can get the +5 from any of the dig I/O pins, and I can evidentally get RS-232 data from the Program port. All I need to do is figure out how to wire it.
_
Unread 26-01-2005, 00:05
FRC #2429
Yes, it looks fine. Connecting the LCD data line to pin 3 of the program/serial port wouldn't smoke anything because it's the serial port's Rx line.
-Kevin
Kevin Watson
http://kevin.org
Unread 26-01-2005, 00:07
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
-Kevin
Excellent. Thank you very much, Kevin. I can't wait to hook this up tomorrow. I'll let you know how it goes.
_
Unread 30-01-2005, 22:44
russell's Avatar
#1430 (WRONG)
Did it work?
Unread 30-01-2005, 23:28
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Heh. I dont think he finished soldering it. Other priority projects took over his (and the person doing the soldering) time. When he gets it finished and working .. we'll get some pictures of it and post it.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
