Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Unread 26-01-2005, 00:12
kshot kshot is offline
#0968 (RAWC)
kshot is an unknown quantity at this point
Send a message via AIM to kshot
Kevin's Commands.h??
Hello All!!
I was just messing around with the programing that Kevin made, but I never found out how I can get that CMD_Drive to work right. Should I insert it as {CMD_DRIVE 1000,0,0} or something like that. Or should I just have CMD_DRIVE;. Should I put this in the user_routine_fast?
Unread 26-01-2005, 10:13
Re: Kevin's Commands.h??
Originally Posted by kshot
I was just messing around with the programing that Kevin made, but I never found out how I can get that CMD_Drive to work right. Should I insert it as {CMD_DRIVE, 1000,0,0} or something like that. Or should I just have CMD_DRIVE;. Should I put this in the user_routine_fast?
In commands.h
struct commands command_list[] = {
{CMD_DRIVE, 2400,		0,	 0},
{NULL,		 0,		0,	 0}
Unread 16-02-2005, 18:58
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
How do you link those commands to auto mode...
Unread 17-02-2005, 17:12
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Check my white paper Autonomous Scripting for some help.
Basically, in robot.c, it reads the array and executes the commands until it finds a NULL.
