Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 22-01-2005, 13:22
zdeswarte's Avatar
zdeswarte zdeswarte is offline
AKA: Zack
None #1240 (LHS Robotics)
Team Role: Electrical
zdeswarte is on a distinguished road
Send a message via MSN to zdeswarte
Electronics Board Construction/Design
I remember seeing a picture of this one team's robot in either november or december; its wiring organization was phenominal. However, I can't find that picture for the life of me, I've been looking for an hour and a half already. If someone remembers any specifics about that picture, like team name or caption description so I can find it again I would really appreciate it.
Unread 22-01-2005, 15:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Need Good Wiring Example
I think you're referring to this picture.
Please see this thread and search before you post.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2005, 00:21
Denny527's Avatar
Denny527 Denny527 is offline
#0812 (Midnight Mechanics)
Denny527 is an unknown quantity at this point
Mounting the Electrical parts on the robot
I'm new at this and I'm wondering:
how do u put everything on ur robot?
Do u use a wood board, a plastic board, or acylic board or whatever?
Also is it a good idea to have everything in one place??
or should we have things apart from each other??
^_^
Unread 26-01-2005, 00:25
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: Mounting the Electrical parts on the robot
This thread shows a really nice electronics layout. Different teams use many different ways to mount the electronics. I think most people would agree that most teams mount all or at least most of the electrical components together. Having it all together can help make the wiring neat and help when you need to fix something. It also helps in the fact that you can run shorter wires.
See you in DC!
Unread 26-01-2005, 00:40
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Any kind of board will work, but the electronics board is a good area to use as little weight as possible on the robot. We have used lexan and wood boards in the past and they have worked fine. Wood boards are easy to trim down and to make fast changes, so we prefer them.
As for placement of your electronics: you can have everything in one place, this helps with troubleshooting at competitions and it looks nice and neat; or you can place certain electronics in different locations that are concealed in your robot, like the spikes and the speed controllers. But electronics like the main circuit breaker and your robot controller, need to be put in a special spot that is easy to get to. Both strategies work fine and are efficient for a robot at a competition.
You should use as little wire as possible, but don’t pull your cables to tight. If you pull them excessively tight, you run the risk of a robot hitting you hard and a wire getting pulled out due to stress. All sensitive equipment needs to be protected with some sort of a shield. Don’t run the risk of allowing a way to damage the robot controller or any other vital electronics device; it will ruin your day.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
Unread 26-01-2005, 08:00
For several years now we have used a punched aluminum sheet available from McMaster. I believe the holes are 1/4". It is light and allows us to tywrap everything in place in case we need to rapidly replace a component. It also allows for tywrapping all the wiring down. It may not be pretty but it gets the job done and allows for cooling air to move through the robot.
Unread 26-01-2005, 10:10
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
The TechnoKats use thin (1/8" - 1/16") Lexan because it's non-conductive, easy to cut/drill, and clear, which can be very convenient when you are trying to see something in your robot from below. We usually tie-wrap everything because it's easier to remove and replace components than it is with nuts and bolts. I'd also recommend making your wire runs as short as possible (especially the high-current ones, such as the battery and drive motors) to minimize voltage drop and get the most out of your battery. Covering the Victors is a good idea too, as metal flakes from drilling/cutting on your robot can get in them and release the magic smoke.
Unread 27-01-2005, 16:52
Denny527's Avatar
Hey thanks for the ideas and pictures guys
^_^
Unread 27-01-2005, 18:29
Hershey's Avatar
Hershey Hershey is offline
You can't name all of my positions!
AKA: Andrew
#1290 (Wolfgang Robotics)
Hershey can only hope to improve
Send a message via AIM to Hershey
OK...I don't think it's the material that u make the board with. I think the biggest problem is the highly recomended 'quick release' mechanizm. Last year, my team had our board hooked on the bot with nuts and bolts. What made it worse was that we forgot the wrench that fit the nuts. As for the material, we went with lexan last year. For testing, we use a non-permanent wood board that will be placed on a more stable material when we want to make the design final. The over all advice, DON'T USE NUTS AND BOLTS FOR YOUR BOARD!
POSITIONS
  • Programmer
  • Team Leader
  • Basic overall (where you need me)
Team 1290
Wolfgang Robotics
Unread 27-01-2005, 21:56
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
i wouldnt make it out of acylic because it is too easy to break. The best thing to do is make it out of 1/8 in polycarb. You also want to keep your components all on one board if possible.
Team 302
Unread 28-01-2005, 00:09
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Although i agree that polycarb is way better for robotics applications then acrylic (easier to drill, stronger, wont break anywhere as easily as acrylic) i disagree about keeping the electrics together on one board.
Although it is a good practice to keep leads for battery and leads going to the motors as short as possible, it is not nessacary to keep everything together in one area, many teams choose to spread things out and this works for them, alot of it is personal preferance and/or working with what space and options you have available.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Hows your electronics board? eR1c599 Electrical 19 16-01-2005 23:54
pic: Jesuit 1097 Electronics Board CD47-Bot Robot Showcase 8 01-03-2004 12:35
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
