Go to Post I believe there is a strong link between a reliable drivetrain and an inspirational FIRST season. - Joe Johnson [more]
Unread 25-01-2005, 09:05
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Do the CIM motors emit a magnetic field?
Has anyone heard that the CIM give off a manget field?
Unread 25-01-2005, 09:38
Re: CIM MOTORS
Julie,
All of our motors have a magnetic field because every one has a magnet inside including the fans. Most are designed to concentrate the field within the motor but I wouldn't lay a tape next to one and expect to get any data to play back.
Unread 25-01-2005, 10:00
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: CIM MOTORS
Easy, way to check for magnetic field is is just use a CRT, slowly move the object towards the side of the monitor, as soon as it starts to distort, stop, if you get it too close, it can permanently damage the monitor.
With our monitors, a CIM will start messing with it from about 1 foot away, not that bad, but still pretty strong.
Why, you worried about it interfering with something?
Unread 25-01-2005, 15:21
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: CIM MOTORS
May I suggest using a black-and-white TV, as they will not be permanently damaged if they come in contact with magnetic fields. But if you dont have one handy, then a CRT moniter and a quick hand should do the job
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 25-01-2005, 16:46
Re: Do the CIM motors emit a magnetic field?
CRTs cannot be permanently damaged by simply putting a magnet near the the tube. It will distort and change purity but all of that should go away with a degausing. Whatever happed to taking a piece of steel (ferrous metal) and holding up to the motor to see if it sticks?
Unread 25-01-2005, 17:19
Gdeaver Gdeaver is offline
FRC #1640
Yes, they have permanent magnets in them. If your looking at a digital compass you'll need to keep it away from the motors and calibrate for hard iron fields.
Unread 25-01-2005, 17:31
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
can wood isolate/lower the magnetic field form motors?
Team 1009
Unread 25-01-2005, 17:58
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
I don't Think so, not effectively anyway.
the only way i can imagine would wood help would be if you used it as a spacer
I have no scientific backing, but my hunch is that you need some sort of dense material or maybe even dense ferrus material to contain a magnetic field.....
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 25-01-2005, 19:13
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
-Leav
To reduce a magnetic field you can do pretty much two things: move away from it or put a conductive material between you and it.
Matt
Unread 25-01-2005, 22:06
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
The magnetic field isn't really that strong. It can pick up light things such as the master links for chain or staples. Then again, you shouldn't put your electronics right next to it because it might mess it up.
Unread 25-01-2005, 22:22
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
out of all the motors the CIM is the motor with the most magnetic shielding and the FP is the one with the least. Cim's are the most reliable motor in the kit. in the many years of their use in first robots i have never heard of one burning up breaking becoming disabled overheating or otherwise failing with the exception of wiring problems.
Unread 26-01-2005, 00:43
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: CIM MOTORS
What about simply a compass?
To lower a magnetic field easiest would probably be a chunk of lead.
We dont have to worry about magnetic fields with our electronics because verything is solid state, and the data on the robot controller is not stored magneticly but written to memory.
-Mike
Unread 26-01-2005, 07:44
Magnetic fields are interesting little beasties. You cannot block them with lead, wood, or copper shielding. Ferrous metals work to a certain degree but combinations of nickel, steel and other metals due tend to work in conjunction to shield the fields by bending them out of the way. A sandwich of high nickel steel, steel, and copper in alternating layers works best. There are a number of materials that are available for purchase but they are expensive and heavy. (Mumetal, guassshield and magalloy were some of the names I have used. I am not sure whether they were manufactured by companies now defunct or not.)
Fields to tend to reduce with distance but depending on the surrounding materials may actually be focused into a particular direction. Remember, magnetic fields, like elctricity, must flow from pole to pole so think of your classic bar magnet picture with the field curving from North to South poles.
Magnetic fields become particularly annoying to electronics when they are changing or moving. Remember that a wire will have current induced in it if it is in the presence of a moving or changing magnetic field. (Sometimes referred to as "cutting the (magnetic) lines") But remember that creating a magnetic field with electric current is what drives our motors. The field generated in the armature works against/with the filed in the magnet of the motor.
Unread 27-01-2005, 09:54
JulieB's Avatar
well........
AKA: Just Julie!
FRC #0538
could it mess up the control interface
Unread 27-01-2005, 10:00
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
I don't know a lot about the physics of it, but I have never had a problem with motors disturbing any of the control electronics.
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
Obtaining 2005 CIM Motors Phil Paspalas Motors 6 19-01-2005 13:53
CD-Swap: CIM Motors Bill Gold Motors 2 11-01-2005 18:47
CIM motors - where to buy spares? Andy Baker Motors 4 16-01-2003 21:09
