Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 25-01-2005, 22:46
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Program Port Y-cable
I saw a reference to a Y-cable for the program port in the new default code. The Y-cable would allow you to use both the program port and the Breaker Panel at the same time. I was wondering if anyone know where I could buy one or a wiring diagram so that teams can build one for them selves.
/* Add your own code here. (a printf will not be displayed
when connected to the breaker panel unless a Y cable is used) */
Unread 25-01-2005, 22:52
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Program Port Y-cable
I was wondering what that meant. Now I understand what it meant, but I am wondering the same thing.
Unread 25-01-2005, 22:54
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
You can buy them here: http://www.stonewallcable.com/dept.asp?dept_id=56
If it will work, I don't know.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 26-01-2005, 00:50
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Wait a second...
Isn't there only one data line?...well, two if you consider each direction a seperate line. If three devices are connected to the same RS-232 line, I'm pretty sure only two of them can talk to each other. The other would either just get confused or interfere with the communciations. Unless of course there's some negotiation I don't know about...
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 01-02-2005, 17:20
AKA: Allen Gregory
IFI has released a wiring diagram for a Y-cable that will serve this purpose.
Y-cable Wiring Diagram
They also have released a device reader that seems very interesting.
Device Reader (Scroll to Bottom of Page)
Unread 01-02-2005, 21:21
The Y-cable seems to be only for printing debug statements on the PC not programming the RC.
LCD wiring to Program port jgannon Control System 10 30-01-2005 23:28
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
2 questions about LAN (10/100) cable. Elgin Clock IT / Communications 19 16-11-2004 12:04
Using the TTL port Max Lobovsky Programming 6 25-06-2004 12:44
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
