Go to Post just flat out, full force, take no prisoners driving - spears312 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 25-01-2005, 17:30
FRANK(WGH) FRANK(WGH) is offline
Webmaster - delphielite.com
AKA: Frank
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Webmaster
FRANK(WGH) will become famous soon enough
Send a message via AIM to FRANK(WGH)
Unhappy PHP Coding HELP!!!
i'm kind of new to php coding and need some help working on my team's page.
I'd like to know some websites where i can find coding help. I'm also looking for someone that I could contact to ask specific questions. What i need help in specifically is, I'm working on profiles and i'd like to just create a template profile page, and then instead of using that page to make the profiles just include the profiles for each person from a text file. This way i only have one page that through the links will turn into many pages. I'm not sure if i'm helping describe my problem or just confusiong people. If anyone can help it will be appreciated.
Frank Bosak
Collegiate Mentor Association
Team 48 - Delphi E.L.I.T.E.
Unread 25-01-2005, 19:32
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: PHP Coding HELP!!!
http://www.php.net has everything on php in there... just search their documentation and function library on their website... Or if you need a script that is not on there:
http://www.programmersheaven.com/
http://www.sourceforge.net/
http://www.pscode.com/
just search through their code there.
- from B B frank
Unread 26-01-2005, 09:06
AKA: Frank
I recognize that i wasn't really clear on what i want to do so here it is. I'd like to use one page and then be able to include a specific include file through the link like this:
(http://delphielite.com/profiles.php?show=fbosak)
this way all i need is to create one completely formated page and then have it include a text file for each team member that has all the profile information.
I hope that this is possible
Frank Bosak
Unread 26-01-2005, 09:12
ahmad's Avatar
ahmad ahmad is offline
ahmad is an unknown quantity at this point
see if this helps :
PHP Code:
<?php
 $fullname
$_GET['name'];
$query=mysql_query("SELECT * FROM $table where name='$fullname'") or die(mysql_error());
    while(
$row mysql_fetch_array($query)) {
$j mysql_num_fields($query);
        for(
$i=0;$i<$j;$i++) {
$k mysql_field_name($query,$i);
$k $row[$k];
$entry=stripslashes($entry);
Echo
" entry";
to see somthing you just type : index.php?name=FRANK
Unread 26-01-2005, 09:35
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Be careful that you don't allow people to show any file on your system. Be sure to restrict it to a particular secure directory. I've heard of horror stories where the mechanism to include files allowed people to view password files and other system files.
Brandon Martus
e-mail
Unread 26-01-2005, 10:22
AKA: Frank
Originally Posted by ahmad
see if this helps :
PHP Code:
<?php
 $fullname
$_GET['name'];
    while(
        for(
$i=0;$i<$j;$i++) {
$k $row[$k];
Echo
" entry";
Where would i specify what to direct frank to?? Is this in a my-sql database??
If so is there a way to do it in another form such as a text document or web site.
Frank Bosak
Unread 26-01-2005, 13:35
ahmad's Avatar
that's right ... this is for my-sql databases ....
the other ones ... i'm not sure so i won't say anything ...
Unread 26-01-2005, 13:54
AIBob's Avatar
AI Programmer
Try this:
profile.php
PHP Code:
<?php
$name
=strtolower($_GET["name"]);
$fname="profiles.txt";
if((
$fp=fopen($fname,"r")))
$lines=split("
,fread($fp,filesize($fname)));
$done=0;
   foreach(
$lines as $line)
      if(!
$done)
$prof=split("///",$line);
         if(
strtolower($prof[0])==$name)
            echo
$prof[1];
$done=1;
   if(!
$done) echo "User profile not found";
fclose($fp);
else
   echo
"There was an error in opening the profiles file";
profiles.txt:
bob///this is the first line of the profile<br>this is the second.<br>etc...
frank///this is the first line of the profile<br>this is the second.<br>etc...
then just go to:
profile.php?name=bob
- from B B frank
Unread 26-01-2005, 17:01
AKA: Frank
Originally Posted by AIBob
Try this:
profile.php
PHP Code:
<?php
$name
if((
$lines=split("
$done=0;
   foreach(
$lines as $line)
      if(!
$done)
         if(
            echo
$prof[1];
$done=1;
   if(!
fclose($fp);
else
   echo
profiles.txt:
then just go to:
This script is just what i'm looking for. I do have one more question though.
Is there a way, that i can in the one line of text that i must contain all the information in, that i can tell it to include a file with the profile. This solution works if all i want to say is conatianed it one line but i need multiple lines and some tables. Take a look at this example:
http://www.delphielite.com/modules/profiles/example.php
i'd like this to be able to be shown on the page.
Frank Bosak
Unread 26-01-2005, 17:18
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
so basically you want to be able to have seperate files for different people?
make a directory on your server as a subdirectory of whereever your profile.php is. call it profiles. chmod it to read/write for the user (i dont know the code)
change the example code to somethign like this:
the code says the file is "profiles.txt"
make it
PHP Code:
$filename "profiles/" $name ".txt"
there are two ways to make your file. you can make them html, in which case you can just read in the whole file and print it out (get rid of the split by line statement)
the second way is to keep the split statement and have the file be like a flat database so you would have one line for name, grade, filepath to picture, etc.
then, just read it in with the example code you have, split it in to an array and print it out.
any questions, cdawzrd at gmail {do.t} com
Cdawzrd
>> www.cdawzrd.com <<
>> www.carobotics.org <<
Speaking of PHP 5... Ryan M. IT / Communications 3 01-08-2004 16:46
openFIRST PHP 5 Compatibility Timothy D. Ginn FIRST-related Organizations 0 30-07-2004 13:45
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
