Go to Post Own your words. - Joe Johnson [more]
Unread 26-01-2005, 11:46
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Center of Mass question
What do you guys think: If we have a foot print that fills up all 28x38 inches with wheels pretty close to the corners, is a 5 foot vertically center of mass too high? How tipsy would our robot be? The COM is actually almost dead center on the robot on the horizontal plane, but still, 5 feet is a lot isn't it?
Alex
President
Team 1072 Harker Robotics
Unread 26-01-2005, 11:55
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Center of Mass question
That is VERY high.
Is this before you extend an arm? or after?
You want to calculate the CoM after you've got whatever appendages on your robot extended completely, as well, to make sure it isn't outside of the base of your bot.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2005, 12:08
AKA: Alex
Originally Posted by Cory
That is VERY high.
This is all with the arm fully extended and a vision tetra loaded.
Alex
President
Unread 26-01-2005, 12:09
Cory's Avatar
AKA: Cory McBride
As long as you're careful and don't jerk the controls back and forth, you should be ok.
If there's any way to make it lower, you might want to try it.
ie: putting motors on the base instead of at the joint on the arm.
2001-2004: Team 100
Unread 26-01-2005, 12:19
AKA: Alex
Mmmmh.... cheeeeeese.....
Alex
President
Unread 26-01-2005, 13:13
Generator of Entropy
FRC #2973 (The Mad Rockers)
Consider these numbers:
Mass "m" located 60 inches high, 17 inches aft of the front wheels (assuming 4 inch wheels).
Summing the moments about the front wheels where they contact the carpet:
(60)(m)(a) = (17)(m)(g), where "a" is either the acceleration where you start driving or the decelleration where you run into something or someone. This says that you will begin to tip over at .283 g's acceleration or deceleration - that's about 9 ft/sec/sec. Most robots will get to full speed (>9 ft/sec) in less than a second, so their peak acceleration must be higher than their average acceleration of 9 ft/sec/sec. And when you run into someone (or they run into you) you will stop considerably faster. I would say you are looking for disaster here.
One interesting note (maybe a little too technical to explain in a simple post) is that this assumes rigid body motion. If your arm / mechanism is flexible it will actually accelerate or decelerate slower than your chassis because of the energy that gets stored in the spring rate. So if you have a tall rigid structure it could be more susceptible to tipping than a soft structure, assuming the decrease in acceleration of the cg more than compensates for the change in downward moment arm to the cg.
Unread 26-01-2005, 13:14
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'm going to go out on a tetra manipulator here and say that a 5 foot high COM is a bad idea. the angle of tipping that would be required to make your robot go over sideways is just a couple degrees. backwards and forwards isn't much better. Just accelerating hard willl make you go over. I remember the box ball collectors of 2002, they fell all the time because they had too much weight up top. Its a big issue. I strongly suggest trying to find a way to lower it. Even 3 or 4 feet would help a lot.
Team Website
Unread 26-01-2005, 13:15
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Assuming your wheels are RIGHT AT the edge of the 'bot, and the center of mass is centered above your footprint, it's only 14" from the tipping point. If you were to tip any more than 13.13 degrees (tan-1(14"/60")), you're going to go on over! Not a pretty picture.
Unread 26-01-2005, 13:20
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
Bacely, robots that have arms for this year, they all have a high COG (max 60in high)
PS: put thing like the 12v and the compesser lower to the ground, and on the opp. side of your arm, if your arm is at the front or back of the robot.
Team 1009
Unread 26-01-2005, 14:36
Please forgive me for using numbers to back up my statements; it's one of my engineering habits.
130 pound robot, 10 pound tetra lifted ~ 8 feet in the air
Example 1: Arm weighs 40 pounds, uniformly distributed vertically; remaining chassis/drive train/battery, etc. weighs 90 pounds, cg at 3" based on center of 6" base structure.
[(40)(50)+(90)(3)+(10)(100)]/140 = 23.5 inch cg height
Example 2: Arm weighs 20 pounds, remainder weighs 110 pounds at 4" height
[(20)(50)+(110)(4)+(10)(100)]/140 = 13.5 inch cg height
Take the weight out of your tall structure and move everything down as far as possible. It's not that hard to do if you design it in to start with. Otherwise, if you're our opponent - thank you very much, and if you're on our alliance please make sure your structure is designed to be plowed across the field; we'd like to have the 10 points for putting you in the end zone with us.
Unread 26-01-2005, 14:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you model your robot and the tetra in Inventor and set the mass properties correctly for everything, you can get a pretty good idea of where it is. Look under the File Menu for iProperties and the View menu for Center of Gravity.
Unread 26-01-2005, 17:03
AKA: Alex
Thank you everyone for the help, I already ran through the calculations and got the unhappy result after my last post. 135 fl-lb of torque needed to tip us =/
not much at all. Our arm is VERY tall at full extension, so it's not so much that its heavy, but more so that it's just big. That being said we're redesigning it to be lighter anyways. We're also considering outriggers. Our center of mass without the arm is probably obscenly low as it is, and i'm fairly sure we can't move much more stuff down.
Alex
President
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
KSC Results archiver 2000 2 23-06-2002 22:19
