Go to Post By far, the worst thing about it was the severe lack of cowbell. There was no cowbell what so ever. Had there been cowbell that would have completely changed everything for me. - Wildcat [more]
Unread 26-01-2005, 13:14
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
using SPIKE relay module with Fisher Price motors
is it possible?
Unread 26-01-2005, 13:18
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: using SPIKE relay module with Fisher Price motors
Technically? Yes.
Against the FIRST rules? Yes.
See rule <R78>.
Unread 26-01-2005, 14:03
Electrical Engineer
Rookie Year: 1995
Originally Posted by 1574aviad
is it possible?
I will be more conservative than Mike D.:
Possible: No.
Against the rules: Yes.
Why I say not possible: Neglecting stall current for a second, the FP motors are 407W at peak power. That is 34A but are protected by a 20A CB. Even if the rules allowed it, your life would be miserable if you use a spike with a FP motor.
Mike Betts
As easy as 355/113...
Unread 27-01-2005, 01:34
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
You can always just program your victor to max teh fischer price out forward or backwards and hook it up to a two direction switch. If this would simplify the control of whatever you're doing for the operator then sure give it a go.
Team Website
Unread 27-01-2005, 01:49
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
That is what I would do. It gives you more options later too if you decide you want speed control also. The only problem is that as you are from a rookie team you may not have enough victors. But assuming this is why you want to hook the FP motor to a spike really there is nothing you can do about it, you will probably just have to get more victors.
need spechs on fisher price motors SCYTE16 Motors 6 23-11-2004 07:19
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Fisher Price Motors... archiver 2001 2 23-06-2002 22:36
fisher price motors archiver 2000 4 23-06-2002 22:36
