Re: Why is the kitbot chassis bowing in horribly
Did lithium grease come with the kit? If so, what does it look like ? =/
No sorry, it was not included in the kit. You should probably pick up a tube at your local hardware store
You can also find lithium grease in your local autoparts store and auto sections of Kmart, Walmart and other similar stores.
Noise in the KOP gearbox is also do to the fact that the retaining rings on the motor shafts grind on the second 50T gear. If you open the gearbox after you've run it under power you'll see a groove in the gear. The ring is harder and will cut away at the gear, robbing you of power and make a horrible sound. Try carefully grinding the diameter of the retaining ring so it clears the the gear.
| KOP Chassis & Transmission Support/Documentation | JVN | Technical Discussion | 0 | 10-01-2005 00:28 |
| the provided chassis material | Andrew Dahl | Kit & Additional Hardware | 5 | 09-01-2003 15:26 |
