Go to Post I am surprised at the relative conservative capability you described on our 2006 machine. As for the 2007 machine, in anticipation of an aquatic game, we have completed a robot that "walks on water" and are well along with one that can "part the sea". - Bill Beatty [more]
Unread 22-01-2005, 23:35
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
Re: Why is the kitbot chassis bowing in horribly
we did put grease on it, i'm not sure what type (not WD-40), is a blue jelly colored grease from motormaster
Team 1009
Unread 25-01-2005, 17:53
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Originally Posted by dez250
Have you greased it with lithium grease yet. If you did, was it a jelly type and not a spray out of a can. I would suggest to use a think lithium grease jelly and not just a spray. Put allot on and spread it around and then run the gearbox, this should work well and get rid of the grinding sounds from the gearboxes.
we got the can type, do you suggest we just finish off half a can in each gearbox?
how quite is your jelly-filled gearbox? how tasty?
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 26-01-2005, 19:02
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Problem was solved. I think they mounted the top bar to tightly and forced it on like that. It is now a nice looking chasis from which we shall practice driving with.
Unread 26-01-2005, 23:01
plutonium83
Posts: n/a
Did lithium grease come with the kit? If so, what does it look like ? =/
Unread 28-01-2005, 02:15
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
No sorry, it was not included in the kit. You should probably pick up a tube at your local hardware store
Elknise
Issaquah Robotics
Unread 28-01-2005, 05:46
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
You can also find lithium grease in your local autoparts store and auto sections of Kmart, Walmart and other similar stores.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 28-01-2005, 21:24
S.Nickens's Avatar
S.Nickens S.Nickens is offline
Morpheus
#0011 (M.O.R.T.)
S.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to allS.Nickens is a name known to all
Noise in the KOP gearbox is also do to the fact that the retaining rings on the motor shafts grind on the second 50T gear. If you open the gearbox after you've run it under power you'll see a groove in the gear. The ring is harder and will cut away at the gear, robbing you of power and make a horrible sound. Try carefully grinding the diameter of the retaining ring so it clears the the gear.
If you think you can, or if you think you can't, you're probably right.
2005 Palmetto AutoDesk Award
2005 Palmetto Judges Award
2005 Palmetto Semi-Finalists
2005 NJ Regional Chairmans Award
2005 NJ Regional Finalists
2004 Curie Div. 5th Seed
2004 Palmetto Regional Winners
2004 Palmetto DC Team Spirit Award
2004 Chesapeke Semi-Finalists
2004 Trenton Semi-Finalists
Unread 28-01-2005, 22:53
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
same thign has happened to us~ we cut some angled aluminum brackets to give some extra support
KOP Chassis & Transmission Support/Documentation JVN Technical Discussion 0 10-01-2005 00:28
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
