Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 26-01-2005, 23:11
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Having trouble with your camera mount?
Just play with it. I took a piece of the one square wide edu bot metal stuff and cut it so it was 1 square x 7 squares then bent it into a U shape with one square on the bottom and three on each side. Then I bolted one side of the U to the camera and the other to the servo head. Took like an hour and isnt very strong, and has all the weight on one side, but it sort of works.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
Camera Mount? AnkurG Electrical 3 14-01-2005 09:26
