Re: Titanium chain & sprokets
http://www.dura-ace.com/publish/cont...ive_train.html Quote:
Campagnolo Std Chainring BOLT circle = 135mm Yes they use a 1/2" pitch chain. No the chaintools aren't that special just smaller. No special parts are required you just add or remove links. Bike chains don't use master links. Yeah they make really narrow chain for the 10-speed cassettes that doesn't even work with the 9-speed cassettes. The advantage is you can get it at any bike shop. |
Pete;
You are correct on the first point. The teeth are ground to help shifting. As a result of that, you end up with an asymmetric tooth profile, which takes torque better in one direction than the other. I think were both right on that one. We seem to be in agreement regarding rest of my points. I think we've gotten a little off topic anyway. |
| Chain Drive Question | Matt_Kaplan1902 | Technical Discussion | 34 | 12-04-2004 14:21 |
| Aluminum chain? | Brawler006 | Technical Discussion | 11 | 24-02-2004 15:52 |
| 25 or 35 chain? | Alan Ing | Technical Discussion | 24 | 02-03-2003 13:56 |
| 1/4" chain and links from small parts | archiver | 2001 | 2 | 24-06-2002 00:18 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
