Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 27-01-2005, 08:11
schenkin schenkin is offline
schenkin is on a distinguished road
Re: Using Custom Inputs on the Controller Board
1. The autonomous mode is disabled if the disable pin is grouned. I made a switch which allows us to enable/disable the robot as well as activate autonomous mode. We also made a dongle which allows us to change the channels the robot was using. This came in handy when we participated in a post-season competition and those running it forgot that by default the robots run on the same frequency. I don't know how many people have these, but if anyone wants instructions to make one, just send me a Private Message.
2. I know how to work digital I/O on the RC, its just on the controller board that I don't know how. In ifi_aliases.h it simply defined by a bizzare string (the trigger on the 1st joystick is defined by "rxdata.oi_swA_byte.bitselect.bit0," which comments tell us is the 5th pin on port 4 [sic] plus what I assume is ground. There are only 4 possible digital inputs defined for each port. Is this the maximum? Also, is it possible to have outputs (ie for extra leds, etc)? I know that we are allowed to use computers connected to the dashboard program this year, but is there a more streamlined way?
--Sam
--Team 486
--Positronic Panthers
--http://www.gotrobot.org/
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Custom Mod Controller. Josh Hambright Electrical 9 17-01-2003 08:05
