Go to Post Anyone riding a Segway looks cool...ask Andy Baker - Kyle Love [more]
Unread 27-01-2005, 11:58
MulletFish MulletFish is offline
AKA: Eric Fischer
FRC #2827 (Lambda Cubed)
MulletFish is an unknown quantity at this point
Relay Assignments
I am trying to assign more than one joystick button to a single relay_rev. I have tried using an "=" sign, I have tried adding a new line but the program recognizes one but not the other. How can I do it? Thanks!
Unread 27-01-2005, 12:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Relay Assignments
The default code includes some code that controls some of the relays, make sure you check if that is overriding some of your stuff.
Team 1257
Unread 27-01-2005, 12:17
Use C's | "or" operator.
relay3_rev = p1_sw_trig | p2_sw_trig;
Unread 27-01-2005, 12:18
AKA: Eric Fischer
Here is the code I have:
relay5_rev = p3_sw_aux1;
relay5_rev = p4_sw_aux1;
There are no other references to the relay in the "Buttons to Relays" section. It seems to me that it should work???
Unread 27-01-2005, 12:24
Fold em oval!
Ah, I misunderstood what you are trying to do (thought you meant multiple relays to one button, not vice versa). Alan Anderson has it right. Use the "or" operator just as he suggested.
Team 1257
Unread 27-01-2005, 12:25
The first assignment sets the value based on the switch on port 3. The second assignment then sets the value based on the switch on port 4, regardless of what the first assignment did. p3_sw_aux1 is completely irrelevant to the final result.
You need to set the value based on a combination of the two switches. The | "or" operator will return a value of zero if both its operands are zero, and a value of one if either or both are one.
relay5_rev = p3_sw_aux1 | p4_sw_aux1;
Unread 27-01-2005, 12:52
AKA: Eric Fischer
Thanks Alabn. I tried that and it still does not work.
Unread 27-01-2005, 13:14
Fold em oval!
Use some printf's or other diagnostic and determine if the trigger that isn't working is actually changing the variable.
Team 1257
Unread 27-01-2005, 13:32
...it still does not work.
You'll have to give more details than that if you want useful help. What are you expecting to happen? How are you testing to see if it happens? What happens instead of what you expect?
Specifically, what do you have connected to the Spike, and what else is it connected to?
Unread 27-01-2005, 14:15
AKA: Eric Fischer
It works! You guys are awesome! Thanks so much!
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
Relay Aliases Backwards Jeff Zampieron Programming 19 18-02-2004 16:27
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Division assignments now available in Team 340 database archiver 2001 13 24-06-2002 03:05
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
