Relay Assignments
I am trying to assign more than one joystick button to a single relay_rev. I have tried using an "=" sign, I have tried adding a new line but the program recognizes one but not the other. How can I do it? Thanks!
Re: Relay Assignments
The default code includes some code that controls some of the relays, make sure you check if that is overriding some of your stuff.
relay3_rev = p1_sw_trig | p2_sw_trig; |
Here is the code I have:
relay5_rev = p3_sw_aux1; relay5_rev = p4_sw_aux1; There are no other references to the relay in the "Buttons to Relays" section. It seems to me that it should work??? |
Ah, I misunderstood what you are trying to do (thought you meant multiple relays to one button, not vice versa). Alan Anderson has it right. Use the "or" operator just as he suggested.
relay5_rev = p3_sw_aux1; relay5_rev = p4_sw_aux1; You need to set the value based on a combination of the two switches. The | "or" operator will return a value of zero if both its operands are zero, and a value of one if either or both are one. Code:
relay5_rev = p3_sw_aux1 | p4_sw_aux1; |
#7
Use some printf's or other diagnostic and determine if the trigger that isn't working is actually changing the variable.
#9
Specifically, what do you have connected to the Spike, and what else is it connected to? |
#10
It works! You guys are awesome! Thanks so much!
| Spike (relay) module pin out | coreyjon | Electrical | 14 | 05-04-2004 07:05 |
| Relay Aliases Backwards | Jeff Zampieron | Programming | 19 | 18-02-2004 16:27 |
| Wiring the relay for the pnumatics | Placebo | OCCRA | 3 | 05-11-2002 23:04 |
| Division assignments now available in Team 340 database | archiver | 2001 | 13 | 24-06-2002 03:05 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
