Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 22-01-2005, 14:20
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: number of joysticks
The rule book overrides the documentation, and if there is no rule prohibiting it than joysticks should be quite legal.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 22-01-2005, 14:44
Hershey's Avatar
Hershey Hershey is offline
You can't name all of my positions!
AKA: Andrew
#1290 (Wolfgang Robotics)
Hershey can only hope to improve
Send a message via AIM to Hershey
Any amount u want. Personally, I suggest 5...if u have an alien on ur team that has a few more appendages than u. actually, 3 maybe. 2 for the drive and 1 for an arm or other appendages.
Unread 22-01-2005, 15:05
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Originally Posted by KoRnPoP
I got a question conserning the joysticks. When we were reading the manual for the Operator Interface it said that we had to use the joysticks that FIRST provided us with, but in the FIRST rule book we can't find nothing about it can anyone help with this and let us know?
You are allowed to use any joysticks that you want for the competition, so long as you can get them to work. Which is at best a very tedious process unless you know what you're doing.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 22-01-2005, 17:13
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Originally Posted by Xufer
Well the real problem is that those white joysticks are HORRIBLE , there were alot of people last year who put in tighter spring and all in an attempt to make them better, but it doesnt help to much. Your best bet is to buy new ones in the past we were given joysticks from CH PRODUCTS the problem is the one they used to give us is no longer made. The newer version of it just has more buttons including a directional hat. Heres a link:
http://www.chproducts.com/retail/j_fighter_pc.html
the good thing is theyre only $20 a piece
But again you can use any joystick you like aslong as you know what the buttons map out to.
I have a question:
Are these ones Serial? Cuz they look really good.
Thanks in advance
Unread 26-01-2005, 03:45
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Originally Posted by pakrat
I have a question:
Thanks in advance
They are 15 pin gameport, just like the joystics you recieved in your kit and just like will plug into the operator interface.
Our team has been looking for compatible joystics for a bit now and are probably going to be ordering these - thanks to Xufer for providing the link.
One quick question for teams who have used these before - do the joysticks have yaw control as well? I have examined the CH site and have found no specifics mentioning yaw control.
Thanks, Jeff
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 27-01-2005, 10:53
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Originally Posted by mgreenley
On a quick sidebar, consider a PS2 controller unless you've really got your heart set on an Xbox controller. We found that to convert it all you need to do is cut the plug off and solder the pins into the corect config. for the OI plugs.
im just wondering... the OI reads 3 potentiometers by passing 5 volts through each, and measuring the voltage output. it reads switches the same way. this setup requires 3 pins for each pot, a ground bus and 4 pins for the buttons; thus the DB15 connector
my question is: how do you connect the one asynchronous serial clock/data line in a PS2 controller to all 8 of the above mentioned pins by cutting the connector off?
i might be missing something, but that sounds a lot like magic
if you can find me a schmatic explaining your post, i will be forever in your debt
"You're not a real programmer until all your sentences end with semicolons;"
Unread 27-01-2005, 15:04
Meandmyself's Avatar
Meandmyself Meandmyself is offline
Registered Magic Programming User
AKA: Gordon
#1123 (AIM robotics Crimson Lightning)
Meandmyself will become famous soon enough
One thing to try is to put tape over the calibrators to keep them in position.
As for the looseness in the joystick, you can always fix that in the code. My team had a "dead zone" around neutral where any joystick input from 117 to 137 came out as 127. That solved our problems.
pwm01 = p1_y;
pwm02 = p2_y;
if (pwm01 >=117 && pwm01 <= 137) {pwm01 = 127}
if (pwm02 >=117 && pwm02 <= 137) {pwm02 = 127}
This should work.
They call me the Idea man.
Not because my ideas work,
But because I have ideas...
I'm not a programmer. I'm an electrical guy who can program. If only I understood C!
www.aim-robotics.org //team website
www.tjhsst.edu/~gburgett //cool stuff for school
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
number of joysticks doy Rules/Strategy 5 01-02-2004 00:05
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
