Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 27-01-2005, 14:53
laxkyle17 laxkyle17 is offline
laxkyle17 is on a distinguished road
Missing solenoid
So it seems that our kit came with 2 of the 4 way, 2 position double solenoids
(http://www.pneumaticsfirst.org/2005Game/images/SMC3.jpg)
However I can't seem to find the bottom part of it (that screws in). Does this not come with the kit? If it does come with the kit, which bag was it included in, and if not, where can I order these?
Thanks everyone.
Unread 27-01-2005, 15:42
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Re: Missing solenoid
Yeah, that would be the manifold, or the base mount. That's a different piece than the actual solenoid. Get the SY3000 pdf and order it. It has a different part number and all. That's what I get from it, because on the parts list is says nothing about the base mount or a manifold from SMC.
ivey
and the pdf is here http://www2.usfirst.org/2005comp/Specs/SY3000.pdf
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 27-01-2005, 15:47
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Actually if you are looking at he kit of parts check off list it is listed under kick-off pickup and is called the sub base. Check with your teams main contact to see if they can ask your kickoff location people if there were some they found. They were included as in the kit but a seperate package.
-Mike
Unread 28-01-2005, 16:18
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Yes it was a pick up item at the kick off
however at the NJIT kick off they were not handed out
and when they were mailed out we only got 1
should we have been mailed 2?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Who's missing parts? sanddrag Kit & Additional Hardware 37 12-01-2005 12:13
Who is missing stuff from KOP? Matthew_H Kit & Additional Hardware 52 05-02-2004 19:52
Anyone missing as many parts as we are? Drew Hopman Technical Discussion 4 19-01-2004 19:06
I'm missing stuff (I think!) anish Technical Discussion 2 13-01-2004 12:08
missing kit parts Stephen Kowski Kit & Additional Hardware 57 22-01-2003 12:27
