Go to Post No robot left behind! - M. Mellott [more]
Unread 27-01-2005, 17:01
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Re: multiple tetra stacking
Originally Posted by elknise
As CNield said, we though about this, but we could not come up with a effective gripper to be able to pick them up. We also thought about how much power we would need to be able to pick all of the tetras up. It also is unpractical and we think that with the time it takes you to stack them and put them up, you could have done the same amount individually.
Also, what happens if you stack a bunch of tetras and the opponent then comes and knocks over the stack. That wouldn't be very fun. All that effort wasted...
Unread 27-01-2005, 17:56
UsmanB UsmanB is offline
Michigan Wolverine CO/2009
None #0123 (123 Cosmos)
UsmanB will become famous soon enough
that'd actually be good, u want ur oppenents to knock down ur tetras in the rules it says that the oppenents cant knock down the tetra's and if they do u own the goal for the rest of the match and i think there were some penalty points
Unread 27-01-2005, 18:21
What I meant was if you were stacking them to place a bunch on a goal at one time. If your robot were in, say, the loading zone, and mine knocked over your stack, then you'd have a problem.
Unread 27-01-2005, 18:29
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Well, I think our arm may be able to pull off stacking more than one tetra (after adjusting our regulator), but we don't plan to do it.
It makes more sense to focus on effectively capping individual tetras to be more precise in forming and maintaining rows. I think that is our key strategy this year (oops!, well, not entirely )
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 27-01-2005, 22:07
yet again, if the opposing team messes with you while u are loading tetras or on the loading zone the opposing team gets penalty.
Unread 28-01-2005, 03:22
n0cturnalxb n0cturnalxb is offline
AKA: Shirley
#1159 (Ramona Rampage)
n0cturnalxb will become famous soon enoughn0cturnalxb will become famous soon enough
Send a message via AIM to n0cturnalxb Send a message via MSN to n0cturnalxb
Yet.. if you stack a stack of tetras on one goal quickly enough, you might be able to make it a hell of a lot harder for the opponent to stack a tetra of theirs on top of that specific goal. it'd be even better if it's the center goal, considering how many potential rows you can get out of that
zip ties and duct tape: the answer to all of life's problems
Unread 28-01-2005, 07:05
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
You can put a tetra on top of the goal with out having to go 2 1/2 feet out
Have you not thought about going over the bottom bar then dropping the tetra unto the goal. So as long as up the human can place the tetra far enough on the robot arm and the arm is in the center of your robot you could put many tetra on at one time and place them all on the top at once without flipping. 5 tetra is not un heard of.
To give you what we had in the past
http://www.valleytech.k12.ma.us/robo...1Robot2001.jpg
this arm went up 14' to place that ball on. It is all about keeping the CG low enough
Building FIRST robots since 1995
BVT Robotics
Unread 28-01-2005, 16:44
Only if they interfere with the actual loading of the tetra. As long as the robot in the LZ retrieves the tetra successfully, there is no penalty. You have to put the tetras somewhere, which would be a stack, and it is not against the rules to knock over a stack as long as you don't interfere with the robot itself.
Unread 28-01-2005, 17:45
one quick question, in autonomous mode if your in loading zone getting a tetra and an opposing team's robot hits u, thats a penalty right?
BNield BNield is offline
BNield is an unknown quantity at this point
I think the only arm that could effectively do this would be an arm that pokes through the tetras. i.e. does not grab the tetras at the top or on the sides. So maybe a forklift kind of arm design?
Unread 28-01-2005, 18:24
Pi Is Exactly 3's Avatar
Pi Is Exactly 3 Pi Is Exactly 3 is offline
AKA: Alex... aka... Zog
#1474 (Tewksbury Titans)
Pi Is Exactly 3 will become famous soon enough
Send a message via AIM to Pi Is Exactly 3
Strategically... I feel that the quantity of tetras placed will be only slightly less important than strategic placement of tetras on the goals. Although if two members of an alliance work on that strategy while another just works on getting large quantities of tetras to rack up points, then it would be a good idea.
-Alex
Vice President
Head of Mechanical
Coach / Strategist
Visit Our Website!
Unread 28-01-2005, 18:46
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
we are thinking of multiple stacking. We are currently making prototypes.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 29-01-2005, 01:18
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I think what will happen is that the multiple tetra stackers won't be stacking a bunch and then capping the whole bunch. They'll probably have multiple "lances"(tetra manipulator term for a stick) coming out of their lifter. For two reasons, one to make it harder to miss a tetra you're trying to grab and two, if you need to you'll have an other available lance to grab another tetra.
Team Website
Unread 29-01-2005, 10:47
The rules jut say that if you interfere it's a 50-point penalty. They don't specify if it doesn't apply at any point in the match.
EDIT: Because I can't post again, I'll just edit the post. Thanks to whoever pointed it out, but it is, in fact, a 30-point penalty. Maybe I need to reread the updates.
Unread 29-01-2005, 11:06
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
50-point penalty
I believe it is a 30-pt penalty....
<G15> A ROBOT may not interfere with an opposing ROBOT while any part of the opposing ROBOT is touching its LOADING ZONE and the ROBOT is in the process of retrieving/receiving a TETRA. It is intended that TETRAS be introduced into play as rapidly as the alliance ROBOTS are able to retrieve and utilize them. Violations will result in a 30-point penalty (i.e. three 10-point penalty flags will be thrown) to the offending alliance.
oh and for the discussion earlier of being to tall and too easy to tip.....why not just make your footprint larger....you just have to fit in the envelope at the START of the match. Use some outriggers like on a crane....
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
Tetra Stacking Art Madness!! Elgin Clock General Forum 5 15-01-2005 19:24
Inventor Tetra Connector team222badbrad Inventor 24 14-01-2005 10:25
Extra tetra scoring AJL930 Rules/Strategy 5 12-01-2005 12:20
stacking robots at regionals Ryan Albright Regional Competitions 5 16-03-2003 08:19
