Re: If only 2 robots make it out
Do you mean the third robot is still in the pits being repair or the third robot is broken down in the end zone and can't move?
If only 2 robots make it to the playing field, are you still able to get the 10 point bonus.
1 is left in the pits |
I think there are two ways to answer your question:
1) You're gonna have a whole lot more to worry about in the match than that 10 point bonus. If there are only 2 robots on the field vs an alliance of 3, you are going to be at a serious disadvantage. While that 10 point bonus may help, you need to have a strategy that will get you the most tetras and focus on the strength of the reamining end of your alliance. 2) I am under the impression that it is generally only courteous to place your robot on the field, even if it is not functioning. This happened a few times last year at regionals I was at. If the robot is still in the endzone, and the other two robots make it back to the endzone, then you can have your tenpoint bonus. This is something you'll have to take out with the alliances you're involved with. Respect their decision. If there robot is too beat up to even make it to the field, there is probably a pretty legitimate reason. Try and plan a strategy for what you would do if that does occur, based around your own strengths and priorities. |
Out of curiousity, if you needed to fix your robot, I assume you couldn't take some part that you don't need at the moment and place it on the field in your robot's place? How is the robot defined?
Get the third robot to the playing field and leave it in the home zone even if it doesn't run. That's the only way to score the bonus with a wounded bot.
I'll bring up another point. The rules say all three robots must be in you endzone.
Come elimination time, the rules state: Quote:
| Robots doing origami! | RoboMom | Math and Science | 4 | 24-10-2004 19:42 |
| coolest robots | Solace | General Forum | 92 | 14-06-2004 13:18 |
| Robots compete in first match (FitN) | Clark Gilbert | FIRST In the News... | 0 | 24-03-2004 18:11 |
| Robots prepped for competition | Brandon Martus | FIRST In the News... | 0 | 24-03-2004 17:06 |
| How are robots lowered? | Yan Wang | Rules/Strategy | 5 | 22-02-2004 22:10 |
