Go to Post - oh dear - Will it be January soon? - JaneYoung [more]
Unread 27-01-2005, 07:12
MarkVH's Avatar
MarkVH MarkVH is offline
AKA: Mark VanHaitsma
FRC #0288 (RoboDawgs)
MarkVH is on a distinguished road
problem with the default code
I ran into a problem with the default code from IFI. The drive pwm out puts are the same for each side when the joystick is moved only in the Y-axis where that should be the case for the X-axis.
Unread 27-01-2005, 08:51
Re: problem with the default code
X axis is left and right. Y axis is front and back. When you move the joystick along the Y axis, you want the robot to move straight forward or backward. That requires controlling the motors on both sides identically.
The default code is doing what it is designed to do, and it is correct.
Unread 27-01-2005, 17:29
MarkVH's Avatar
yes that I realize. Right now I have one side wired backward so it will go straight. I know that is not FIRST legal.
Unread 27-01-2005, 17:55
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
What do you mean wired backward. If you mean the M+ to the black wire coming off the motor and the red to the M- this is completely legal we have done it in first many times before.
Unread 27-01-2005, 20:26
MarkVH's Avatar
Thanks thats a relief.
Unread 27-01-2005, 21:19
Rule <R72> specifies the colors only for constant polarity circuits, which the output of the victor is not. When you are going forward there is 12v on the M+ and ground on the M-. When you are going backwards, there is ground on the M+ and 12v on the M-.
Unread 27-01-2005, 21:44
MichaelGoldfarb MichaelGoldfarb is offline
AKA: Goldfarb
FRC #0312 (Heatwave)
MichaelGoldfarb is an unknown quantity at this point
Send a message via AIM to MichaelGoldfarb Send a message via MSN to MichaelGoldfarb
You can switch the X-axis in the default code by subtracting p1_x value from 255.
Example:
Limit_Mix(2000 + p1_y + (255 - p1_x) - 127);
I'm crazy!
Unread 28-01-2005, 00:04
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Example:
You would need to invert the whole thing if the robot is driving correctly and you have the motors "backwards" not just invert the x-axis.
But I say leave the wires "backwards" and let the processor have a few extra cycles for other things. Heck, the victors aren't labeled this year, so just put your own lables on them, and have the N+ and M- switched on those to prevent confusion.
Problem running compiled code jskene Programming 10 23-01-2005 21:13
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
Strange IR sensor movement with default tracker code wun Programming 5 19-03-2004 10:51
default code and the actual robot tml240 Programming 15 24-01-2004 11:31
