Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Unread 27-01-2005, 19:40
DinkyDogg DinkyDogg is offline
DinkyDogg is an unknown quantity at this point
Combining objects in 3D studio?
In 3DS Max, is tehre a way to comine multiple objects into one, so that when I select one it selects them all? That would be pretty helpful. I'm using 3D studio Max 6.
Thanks for any help!
-Jake
Unread 27-01-2005, 19:58
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Combining objects in 3D studio?
If you are wanting to perminatly group objects together (like 2 parts being welded together) you can use Boolean commands. I forget exactly were they are though. Where ever they are, you want to add them together. There are little icons that represent the different boolean functions. (At least there were in 4 and 5). You select the kind of function you want to do and then select 2 parts you want to join. You can join more, but you need to do many additions.
If you are wanting to put parts together (like legos), you want to use the group command. It should have it's own menu in the menu bar. You select the objects and just go to group. You may want to rename the group though (Group 1 isn't very descriptive). You can group boolean objects and use boolean on grouped objects, but if you do the latter, you can't really undo it, they are one part now.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 27-01-2005, 22:26
UsmanB UsmanB is offline
Michigan Wolverine CO/2009
None #0123 (123 Cosmos)
UsmanB will become famous soon enough
boolean is in the create panel, and then u have to choose booleon compounds from drop down menu i believe, too lazy to open 3dmax
Unread 27-01-2005, 22:36
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Just a question, why isn't this in the animation thread? I would have never seen this unless I was reading the portal.
To get to the boolean, go to the create panel, there should be a drop down menu set at Standard Primitives (unless you changed it), select compound objects, and boolean should be one of the options.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 28-01-2005, 01:33
I didn't realize there was one. Thanks, all my animation/modeling related inquiries will be posted there now!
The Group tool sounds like what I want. I've used booleon before but i have many objects I would like to combine, and it would be nice to have it be reversible.
Unread 28-01-2005, 19:46
Sorry guys, but I still can't figure out how to group objects. I don't see a button or menu bar or anything anywhere, and the help files aren't helping me. Could any of you give me specific instructions about how I could objects so I can select them all with one click (not the boolean union commands). Thanks!
-jake
Unread 31-01-2005, 17:09
pezdispenser pezdispenser is offline
Team Role: Animator
pezdispenser is an unknown quantity at this point
-jake
All you have to do is select the objects (using CTRL-click), go up to the "group" drop-down menu, and hit group.
CAD to 3d studio max vivniko Inventor 3 14-02-2004 12:24
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
Help - objects won't move in Max Kevin Thorp 3D Animation and Competition 7 28-01-2003 12:49
