Go to Post Are you saying you want to submerge your circuit board in an open container of liquid nitrogen? - Ether [more]
View Poll Results: Are you planning to stop vision tetra caps in autonomous?
Yes we're going to stop them 37 44.05%
No they can have there vision caps 47 55.95%
Voters: 84. You may not vote on this poll
Unread 27-01-2005, 13:14
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Exclamation Midfield Collisions
I want to put a warning out to everyone in design build mode, to seriously consider the autonomous midfield collisions that will be taking place. I know many of you will say "well it's not graciously professional to intentionally collide in the game". Well let me say that most of the seasoned teams out there are thinking the only way to pull off autonomous vision caps, or stop them - is to do it as FAST as possible. This means there will be robots going blazing speeds through the coarse with no one at the wheel to avoid a collision. Then to compound the problem, there are only 2 access points to traverse to the opposite side of the field. This means almost by default, this game will begin to boil down to the teams that have the design and guts to come flying through that opening at full speed with the intent to stop a vision tetra cap. So another thing to consider is your tetra gripper mechanism/arm may get attacked in autonomous by a bot traveling 12'/s or more, with no regard to your bots shape or frailties. Basically a computer doesn't care. If the design thats coming after you is rigid you could be looking at some pretty serious damage before autonomous ends.
I know some of you are already brewing at the thought of this happening to your babies. But it's going to be part of the game. So please build them tough and with low CG's. The ref's can't protect you during autonomous. Everyone knows to go easy during manual, but it's the "autonomous valley of death midfield collisions" and the vision tetra seeker stoppers during autonomous that will inflict the most damage.
If you plan to cap during autonomous and your drive or mechanism are slower than around 7 seconds to complete the cap. It's very easy to make the kit chassis stop you. And you WILL get hit with no regard to front/back or sides. So if you're holding a tetra up 8-9' in the air you better do some good scouting before you try.
Also I'm very concerned for the electronics from the kit. I don't know how many Autonomous pounding's they're going to be able to take. If you decide to shoot the gap, and so does the opposing team. And you both meet midfield going 12'/s thats a 24'/s collision. Parts will go flying, batteries will come out. PWM's will pop loose. Arms will swing wildly and twist. Be careful about your choice of autonomous.
You can't blame anyone for using this method either. It's logical to stop the best cappers as fast as possible. With the equipment given in the kit, it's quite easy to do. Although the teams that choose to do this may have a short life span. I predict many of you will decide your arm isn't working out and it's more of a CG risk to keep it, then switch your strategy to a defensive chassis. Before you know it, the only teams left capping will be the ones who heeded this advice, or were thinking of it all along.
I'm going to add a poll to prove my point.
www.179swampthing.org
Unread 27-01-2005, 14:19
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Midfield Collisions
I fully expect auto mode to be aggressive. Auto mode comes with it a different set of ROE. I've considered a lot of auto moves aimed specifically at stopping teams from capping a vision tet, including running the bot at speed through all the possible tet locations, running circles around the center goal at high speed and generally turning my bot loose on the field.
Is it GP? I don't know exactly. I'm also not sure just how the rules apply to auto mode. As Dan said, the computers don't care, and the ref's may not start throwing flags for robots acting aggressively during auto mode. I'm not out to damage anyone, but at the same time, I am out to win. Keeping the other teams from getting a vision tet could be a deciding factor. The rules say no high speed ramming. But is this a case of 'punching the air, and if you happen to be in that air it's not my fault'? I'm really not sure. Should the whole 2:15 of the match be reffed the same from a ramming/aggressive play standpoint?
-Andy A.
Unread 27-01-2005, 15:13
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
I've said it before ... and I'll say it again. I will be very surprised if more than about 1%of all robots (maybe 10 of around 1000 teams) will have the capability to consistently acquire AND score the vision tetra during autonomous. Please prove me wrong ... but I am skeptical. IMO there are several productive strategies that could be chosen for autonomous and that is what I expect our team to focus on. Also, as a referee, I will do my best to enforce the rules as written and as instructed by FIRST . You may be asked to disable an "overly aggressive" autonomous program to avoid penalties and/or DQ ... yes ... even in autonomous mode.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 27-01-2005, 15:27
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
i garuntee there will be several teams who can cap the center goal with a vision tetra despite virtually any opposition. however, i will also say that many many more teams will attempt to make robots like this and fail. auton may be the most important 15 seconds of the game, but the robots who are designed specifically for auton will generally fail. we cant forget that no matter how good an auton mode is, the opponant can always catch up in driver mode.
Unread 27-01-2005, 15:28
Stu,
A few weeks ago I would have agreed with you but I think the camera and software are going to make a lot of teams "auto ready" this year. For that reason I believe the number is higher. Still less than 10% of the teams will be effective in collision avoidance and accuracy. (IMHO)
Unread 27-01-2005, 21:42
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
"If you can't do something cool, like cap tets in auto, you can at the very least ruin the hard work of others by ramming them into submission." - The Prevailing Attitude
I happen to think there is nothing wrong with that attitude, and I intend to play both sides of the game well. The real challenge comes when you starting blocking the blockers...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 27-01-2005, 22:00
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Scout so that you're not in doubt!
Know the autonomous programs of all of your opponents and alliance partners for every match so that you can take evasive action and avoid collisions. Program so that you have a couple of switches to change up the autonomous in advance of setting the robot on the field. For instance, if you and a partner both have a center-capping program during auto mode, defer to the more consistent capper by flipping a switch that allows you to cap a side goal or drop a hanging tetra.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 27-01-2005, 22:12
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Wow! You mean that simple little boxes on wheels, that can't do anything else in the autonomous period except drive around (which they can do just by building the kitbot), might actually be able to play a very important role by protecting their vision-tetra-capping-capable alliance partners from opposing onslaughts?!!? Just drive really fast from the starting position to one of the two "channels" between the middle goals, and patrol there, block the opponents efforts to disrupt the alliance, and enable your alliance to score points during autonomous! And maybe if the simple little box on wheel teams wasn't "quite there" with their autonomous software, a vision-tetra-capping-capable alliance partner that wanted them to fulfill that role might even be able to just give them the simple autonomous routine that they needed while they were at the competition! That seems like a pretty cool idea! Who'da thunk o' dat?!
Unread 27-01-2005, 22:30
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I think that is really wishful thinking. Last year, my team was almost always the most friendly and willing to interact out of all the teams we played with. There were numerous oppurtunities where we could have benefitted (and vice versa) from people from other teams helping with software, yet very little happened. One programmer from another team did help out a bit, but the code he gave us was mostly useless because we decided it was too risky to try it without testing it.
Sure teams can lend each other spare parts and give each other advice, but I think its pretty unlikely that you will see many teams reporgramming other teams bots in the 1/2 hour or so that they have to prepare for matches.
Team 1257
Unread 27-01-2005, 22:32
phrontist's Avatar
Proto-Engineer
Sorry if I'm coming a bit late to the party. I was out in the alley with a group of weirdos muttering about Amethyst colored glasses, hexagons, and Beatles albums while you were thinking up all this stuff, so I might be a bit behind the curve.
Unread 27-01-2005, 22:34
phrontist's Avatar
Proto-Engineer
I think it's possible, but very hard indeed. The problem comes with having time to test it.
Unread 27-01-2005, 23:01
dlavery's Avatar
Curmudgeon
Yea, I guess so. I must have been daydreaming. I realize that giving them
{CMD_DRIVE, 8500, 0, 0},
{CMD_TURN, (-1500), 50, 0},
{CMD_WAIT, 1000, 0, 0},
{CMD_DRIVE, 0500, 0, 0},
{CMD_DRIVE, -1000, 0, 0},
{CMD_DRIVE, 1000, 0, 0},
{CMD_JUMP, 4, 0, 0},
{NULL, 0, 0, 0}
in a little text file would be too hard.
-dave
Unread 27-01-2005, 23:25
Fold em oval!
Mr. Lavery, if you have the guts to take that from some stranger's hands (regardless of the strangers intentions or background), drop it into the robot you have worked for 6 long, hard weeks on right before one of the maybe 25 actual matches your robot will play, you are a braver man than me.
Team 1257
Unread 27-01-2005, 23:32
dlavery's Avatar
Curmudgeon
That is what practice fields are for.
Unread 28-01-2005, 00:00
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I have two plans for teams not having much luck with their cameras, both involving use of gyros and encoders. Your first option is to have your autonomous dedicated to blocking opposing blocking bots (Obviously I "borrowed" this idea). This is a good plan because the very good teams will likely have camera autonomous and will find you to be a valuable partner. The other plan is to have an arm with an aluminum tetra shape on the end, and two three way switches, one to select your starting location, and the other to select a goal which your robot will then drive to and put its aluminum tetra on top of for the duration of autonomous (It would be a part of the arm, not something it sets there then leaves obviously). Not only is this a more GP way of blocking than simply careening about with the intent of destroying, but it should also be moree effective. If you were really good you could even have a giant folding arm that covers all three goals .
Team Update #20/Scoring Examples ahecht General Forum 40 05-03-2003 23:07
