Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 27-01-2005, 22:57
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: pneumatics lifting forces
You can look it up in a table, but here is the calculation so you understand.
F=PA, or Force = Pressure x Area.
If you are working with a 2" dia. cylinder, the area = pi(r)^2
or 3.14*(1)^2 =3.14 square inches.
(remember to use the radius, not the diameter)
If you are working at 60 psi, the force is 60 psi x 3.14 sq in = 188.4 pounds of force in the extending direction.
To determine the force in the retracting position, you do a similar equation, except you have to subtract out the area of the rod, because the air pressure cannot act on it.
Same 2" dia. cyclinder = 3.14 square inches. Assume the rod = 1/2" diameter.
Area of the rod = pi(.25)^2 = .196 sq in.
Effective area of the retracting end = 3.14 - 0.196 = 2.945 sq. in.
If you are working at 60 psi, the force is 60 psi x 2.945 sq in = 176.64 pounds of force in the retacting position.
You have more force in the extending direction than the retracting direction, because of the smaller area.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 27-01-2005, 23:32
occra 23.
AKA: ryo
None #1481
my english teacher would be ripping at you now i think. or maybe me if youre correct and im not. wouldnt it be
You have more force in the extending direction than the retracting direction, because of the larger area? as the area is reffering to the extending direction rather than the retracting? ugh. i hate english. i really shouldnt be trying to act smart like this cuz im prolly gonna look like an idiot again and yea. well back to the topic.
dont forget pulleys/levers/cams/etc will increase or decrease max lifting weight.
double the range and half the max weight liftable (is that a word? )
or double the weight liftable and half the range. so whether its usable on your arm or no, how much stroke do you have? how much range do you need? how big is your cylinder inside radius? how many cylinders will you use? how much pressure will you be running? how much air will you be storing and how fast can you pump it up again? and most importantly, do you like using pneumatics? personally i loveum. never had any problems withum while motors bug me
Unread 28-01-2005, 00:29
ngreen ngreen is online now
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Yep. F=PA. Double the cyclinders, double the area, double the force. Most people use the cyclinder as levers so know how much you want to lift and how far you want to move it. Then you can find where you need to place cyclinder(s), how many cyclinder, length of stoke, size of bore, the pressure you need to run at, etc. With pneumatics you only need to use what you need. Just figure how much you need to lift with respect to where you are lifting if from and you'll be fine.
Unread 28-01-2005, 08:11
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
When sizing a pneumatic application, another thing to think about would be side loads and efficiency losses.
For instance, working from the numbers Chris posted above, there are many situations where you will not get your entire 176 lbs (retracting) for a 2" cylinder at 60 psi. If the rod of that cylinder is experiencing any side loads, then more friction is created inside of the cylinder. A certain amount of force is needed to overcome this friction. This amount may be up to 1/4-1/3 of the force of the cylinder, if the side load is significant. Therefore, cylinder output forces in these situations could be only 70% - 80% of your calculated force.
Andy B.
Unread 28-01-2005, 08:35
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Added note to "Save as"
Andy B.
I will go further and say that there is no legal way to move anything at the rated max forces for these cylinders. The cylinders can HOLD the max rated force, but they cannot move with that much force. Consider these the stall forces.
Do not forgot the time dimension part of the power equation. Cylinders also have a force versus time curve for each given pressure . My team has done some experiments and have proven that these curves are not linear. I have attached a sample of our experimental results. It is difficult to characterize pneumatics because the entire system affects the available airflow volumes (think of a current limiting analogy from electronics), so these curves are very dependent on your set up. I'm too busy right now to go into any more details but I may do a white paper on the power curves of our pneumatic systems during the off-season.
Don't forget to do a "Save As" on the XL file.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 28-01-2005, 09:35
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
And to add further....
There may also be a derating of force based upon the angle that the force is applied by the piston. For a good overall explanation, go to http://pneumaticsfirst.org and down load the powerpoint presentation dealing with pneumatics.
http://pneumaticsfirst.org/media/PneuAndFIRSTFinal.ppt
Originally Posted by Raul
Added note to "Save as" I will go further and say that there is no legal way to move anything at the rated max forces for these cylinders. The cylinders can HOLD the max rated force, but they cannot move with that much force. Consider these the stall forces.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
General Pneumatics Drok00 Pneumatics 8 11-01-2005 23:35
pneumatics and joysticks Jared Stofflett Pneumatics 3 24-02-2004 23:56
pneumatics and joysticks Jared Stofflett Programming 1 24-02-2004 17:45
oil for for Pneumatics nragod Pneumatics 8 03-02-2003 22:30
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
