Go to Post That settles it, no questions left. Water game. - Lil' Lavery [more]
Unread 25-01-2005, 13:36
DAN THE MAN DAN THE MAN is offline
DAN THE MAN is an unknown quantity at this point
Globe motor mounting
I am looking for a strong reliable way to attach a globe motor to a small gear. In previous years we have bored out the gear to the diameter of the globe motor shaft and then ramed set screwed onto the flats of the motor shaft. This method worked but it wasn t very reliable and constantly came loose. I was also thinking of somehow boring out the gear to the same shape as the globe motor shaft but i couldn t find a good way of doing this with our limited machine shop capability. If anyone has any info about how to attach gears to the globe please let me know.
Thanks
Dan the Man
Unread 25-01-2005, 13:42
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Globe motor mounting
I asked almost the same question a week or so ago: http://www.chiefdelphi.com/forums/sh...ht=double+door
Basically, either cut the hole with mill, edm, waterjet, etc, or clamp the gear/sprocket on either directly, or by bolting it to the clamp.
Team 1257
Unread 25-01-2005, 13:55
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Last year, my ascending system used two globe motors. I did what you want to do, I bored the two ends of the main drum with the shape of the output shaft, the motor just slid in, and that was it, no set screws to worry about. It was however, a pain in the butt to mill by hand (which is what I did) - but it is possible. Of course, if you could, and the design permits (mine did not) you could always use wire EDM, or water jet like the above person mentioned, also do not forget about CNC milling, as it would have worked for what I needed it to if we had a CNC mill large enough. I think using the technique you used in the past was good in a pinch, but I would constantly be worried about the set screws. Globe motors rock, and I had two, because everyone was afraid to use them (no side loads are tolerable) - so remember that!! don't just cantilever the gear without proper shaft support, or you will eat the gearhead in a second! Good luck with your project.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 28-01-2005, 04:41
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We have used the globe motors for several different applications.
We had a square hole EDM'ed out of the center of a sprocket than had a square block made that fit the square hole and the oval shaft of the globe motor. It was sweet. Very precise EDM'ing.
Wayne Doenges
CAD Mentor
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 28-01-2005, 07:30
We use globe motors on our satellite dish feed assy. In order to insure that there is no slipping of the gear, a small hole is drilled through the gear and motor output shaft and a drill rod (drill blank) or roll pin is inserted to hold the two together.
Unread 28-01-2005, 11:04
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Thanks
Dan the Man
The tool you are looking for is called a broach. A broach with the appropriate width will give the shape hole you need. I don't think broaches are terribly expensive, though I must admit our machine shop has never made us pay for one.
Either that or find an EDM shop nearby. It is a small enough job you might get it done for free if you ask nicely and the machine is idle at the moment.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 28-01-2005, 11:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They can be... I needed a hex broach last year and it ran upwards of $115. That should be cheaper though
Im sure you could definitely get a shop to do it for you for free or a reduced price.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2005, 11:37
coreyjon's Avatar
Flight Engineer
I never thaught to use a broach...that would definately would have been easier than doing it manually on the mill...I think our team is getting ready to buy a press (in the past to put key ways in gears we sent it out to a mentors shop, but never did I realize they created that size broach. A note about drill rod,before I knew what drill rod was..I tried cutting it on a gravity feed band saw....not soon after was I getting yelled at for wasting the blade...and I wondered why it wasnt cutting..silly me. I learned my lesson.
Unread 28-01-2005, 11:56
Fold em oval!
I don't think they do create that type of broach. I have never seen any, at least.
Team 1257
Unread 28-01-2005, 12:15
coreyjon's Avatar
Flight Engineer
I believe they are made, but not on large scale, not at least from what I found. I believe it would fall under the "oval double radius" broach. I found a company that makes custom broaches, but you can bet it would cost a lot of money, and probably time. So, I'm not upset that I spent so much time on the mill, I learned a few new tricks doing it that way.
Unread 28-01-2005, 14:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Isn't it just a standard "Doube D" broach? I know there is such a thing, but I don't know where to get it.
Unread 28-01-2005, 15:15
I always thought a broach was something you used to finish what was already roughed in. (i.e. an edm or wire operation needs to be finished with a broach to make it smooth and accurate.) Any professional machine ops out there to answer?
Unread 28-01-2005, 15:38
I am no professsional machinist but I have done keyway broaching. It is basically a "staircase" of cutting edges and with each "step" it takes off a little more material. For the keyway, you start with the round bore, but the broach does the entirety of the slot. They have hexagon broaches too. You start with the round hole and on the broach may be like a foot long and on each step the cutter gets a little larger and a little more hex shaped and by the time it gets all the way through you have a full hex. I really thought there were Double D broaches, but I could be wrong.
Unread 28-01-2005, 17:01
Generally Useless
There are various kinds of broaches. We have one that was specially purchased to make a hole that fit the old Van Door motor shaft. Our sponsor provided it, so I have no idea how much it cost. I'm not sure whether or not it will fit the new Slider motor, though the output shaft is obviously different. Our sponsor also has a set of key way broaches which we have used occasionally. They all work as sandrag has described
"Who is John Galt?"
Unread 14-02-2005, 16:01
ArrBeeBee ArrBeeBee is offline
ArrBeeBee is an unknown quantity at this point
hey I was just wondering, how, exactly, did you guys get the sprocket to fit with the globe motors, like did you guys use hub or hubless sprockets? Thanks.
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe motor backdrive!! Srkasner Motors 19 08-03-2004 00:10
Globe Motor archiver 2000 4 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
