Go to Post it was beautifull just beautifull... then i took my earmuffs off. - Tytus Gerrish [more]
Unread 28-01-2005, 07:40
Re: Battery Mounting
Originally Posted by Eria4044
Someone on my team wants to know if the battery has to be mounted a certain way, or if it can be mounted any way we want. Any help will be appreciated.
This battery can be used in any orientation without a problem. It can be charged in any orientation except upside down if you plan to charge while inside the robot. Don't forget that the battery also makes a great ballast/counter weight if you place it strategically in your robot. Securing the battery is essential, a small frame and 1" velcro work very well. A small case with a hinged cover that you can tywrap closed works as well.
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
