Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 28-01-2005, 11:04
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Globe motor mounting
Originally Posted by DAN THE MAN
I am looking for a strong reliable way to attach a globe motor to a small gear. In previous years we have bored out the gear to the diameter of the globe motor shaft and then ramed set screwed onto the flats of the motor shaft. This method worked but it wasn t very reliable and constantly came loose. I was also thinking of somehow boring out the gear to the same shape as the globe motor shaft but i couldn t find a good way of doing this with our limited machine shop capability. If anyone has any info about how to attach gears to the globe please let me know.
Thanks
Dan the Man
The tool you are looking for is called a broach. A broach with the appropriate width will give the shape hole you need. I don't think broaches are terribly expensive, though I must admit our machine shop has never made us pay for one.
Either that or find an EDM shop nearby. It is a small enough job you might get it done for free if you ask nicely and the machine is idle at the moment.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 28-01-2005, 11:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They can be... I needed a hex broach last year and it ran upwards of $115. That should be cheaper though
Im sure you could definitely get a shop to do it for you for free or a reduced price.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2005, 11:37
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
I never thaught to use a broach...that would definately would have been easier than doing it manually on the mill...I think our team is getting ready to buy a press (in the past to put key ways in gears we sent it out to a mentors shop, but never did I realize they created that size broach. A note about drill rod,before I knew what drill rod was..I tried cutting it on a gravity feed band saw....not soon after was I getting yelled at for wasting the blade...and I wondered why it wasnt cutting..silly me. I learned my lesson.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 28-01-2005, 11:56
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I don't think they do create that type of broach. I have never seen any, at least.
Team 1257
Unread 28-01-2005, 12:15
coreyjon's Avatar
Flight Engineer
I believe they are made, but not on large scale, not at least from what I found. I believe it would fall under the "oval double radius" broach. I found a company that makes custom broaches, but you can bet it would cost a lot of money, and probably time. So, I'm not upset that I spent so much time on the mill, I learned a few new tricks doing it that way.
Unread 28-01-2005, 14:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Isn't it just a standard "Doube D" broach? I know there is such a thing, but I don't know where to get it.
Unread 28-01-2005, 15:15
I always thought a broach was something you used to finish what was already roughed in. (i.e. an edm or wire operation needs to be finished with a broach to make it smooth and accurate.) Any professional machine ops out there to answer?
Unread 28-01-2005, 15:38
I am no professsional machinist but I have done keyway broaching. It is basically a "staircase" of cutting edges and with each "step" it takes off a little more material. For the keyway, you start with the round bore, but the broach does the entirety of the slot. They have hexagon broaches too. You start with the round hole and on the broach may be like a foot long and on each step the cutter gets a little larger and a little more hex shaped and by the time it gets all the way through you have a full hex. I really thought there were Double D broaches, but I could be wrong.
Unread 28-01-2005, 17:01
Generally Useless
There are various kinds of broaches. We have one that was specially purchased to make a hole that fit the old Van Door motor shaft. Our sponsor provided it, so I have no idea how much it cost. I'm not sure whether or not it will fit the new Slider motor, though the output shaft is obviously different. Our sponsor also has a set of key way broaches which we have used occasionally. They all work as sandrag has described
"Who is John Galt?"
Unread 14-02-2005, 16:01
ArrBeeBee ArrBeeBee is offline
ArrBeeBee is an unknown quantity at this point
hey I was just wondering, how, exactly, did you guys get the sprocket to fit with the globe motors, like did you guys use hub or hubless sprockets? Thanks.
Unread 14-02-2005, 21:47
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
I used the globe motor like a lathe and turned it down... Hooked it up to a 12V, put the gearhead in a vice, and held a file against it. It fits an FP pinion now, but sadly its too small due to some smoothing files that probably shouldn't have been made. Epoxy stripped twice, what do you think about JB weld on the armature? Would it hold? I cant see easily putting a pin into the FP gear without screwing up some teeth bigtime.
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe motor backdrive!! Srkasner Motors 19 08-03-2004 00:10
Globe Motor archiver 2000 4 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
