Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 27-01-2005, 15:28
Starman Starman is offline
Starman will become famous soon enough
Original application of Jideco motors
Does anyone know the type automobile the Jideco motors were used in? We would like to get a mating linear track out of a junked auto if we can identify make and model.
Unread 28-01-2005, 11:50
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: Original application of Jideco motors
While I can't give you a specific model, I can tell you that jideco motors where used (are used) in Nissan cars, and possibly some Isuzu vehicles as well. I think your best bet is to hunt for the Nissan cars that may use them as I believe some 70% of jidecos sales goes to Nissan motor company's. There are other ways of finding belts that work with the motors, as I have seen some teams in the past with them.(or systems very similar) I'll take a look at what kind of belt it wants, and take a look around the web to see if I can find anything that would work. Best of luck.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 28-01-2005, 11:54
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I do not believe you will find a rack to mesh with these gears because the window lift mechanisms I have seen use large gear sections (~120deg and 8" radius) to mesh with the window motors.
Team 1257
Unread 28-01-2005, 12:19
coreyjon's Avatar
Flight Engineer
ahh, I may have read the initial post wrong, if in fact they are looking for a rack (and not a belt - I may have been confused, thinking about some of the motors we had in the past) then you may not be able to find what you want. I'm not saying it dosn't exist, but it may easier to try and come up with a differant way.
Unread 28-01-2005, 12:30
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Past kits provided the track and window tape, as well as the mating thing (pully? sprocket? pinion? I'm not sure what it's called). There are three main types of power windows: the gear and arm system you describe, a cable and pully system, and a tape driven system. The motors in the kit are designed for the third.
Zan Hecht
Unread 29-01-2005, 18:55
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Wink Re: Original application of Jideco motors
I'm not sure of which vehicle the Jideco motors came from. However, as far as I know, the Nippon-Denso motors were from a '91 to '94 Ford Taurus. These motors are pretty much the same so it shouldn't be a problem. I've tried to find the same linear thing that you're looking for...we've got the same idea. I couldn't find it on the ford parts online catalog.
Great minds think alike,
Mike F, team 1279
Jideco motors wanted for trade RobZeuge Technical Discussion 6 20-02-2002 16:44
The scoop on the Jideco motors... Joe Johnson Motors 3 30-01-2002 10:00
