Go to Post bump. - connor.worley [more]
Unread 28-01-2005, 11:57
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Playstation Controler
Originally Posted by AIBob
you cannot really use a ps controller, not because of the rules, but because of the way it is set up..
The controllers for FIRST are analog. PS controllers are digital.... it doesnt match, you will find some problems if you try it.
You cannot immediately write off using the PS controller for the robot, simply because it is digital and the controller has analog inputs. There are digital input on the controller as well, which gives that option if you can figure out how to make it work with those digital inputs. Also there is the option of producing a Digital to Analog converter. The same way that the robot converts the analog signal to digital so that it can process it, you can do the reverse and give it an analog signal from digital.
I'm sure you can find a digital to analog converter online.
Saying that something cannot be done, is always good inspiration for someone to find a way to do it.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 29-01-2005, 18:12
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
I didn't say that it couldnt be done, well atleast didn't mean it in that way, I said you would have problems, I am sorry if you misinterpretted me, but i meant that you would have to search around for one and have some other problems. Please forgive my bad wording.
- from B B frank
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
Joystick controllers archiver 2001 6 24-06-2002 00:57
joystick problem archiver 2000 12 23-06-2002 23:08
