Go to Post This problem will be solved by one of the largest problem-solving machines in the world...the FIRST community. - ZZII 527 [more]
Unread 27-01-2005, 23:36
haverfordfords haverfordfords is offline
haverfordfords is an unknown quantity at this point
Do defensive, low scoring tactics work?
I apologize in advance if this was brought up before, but I haven't found anything on the topic.
Say you had a robot without an arm. Strategically, you could just take tetras from the human player and depositing them into the goal and repeating. Also, I guess you could play some sort of defense, possibly going as far as to remove tetras from the opponent’s goal. You could also get some tetras onto the field if requested. You would get back to the line for the bonus 10 pts. if applicable.
Now my question is, seeing as this strategy only nets a few points, would you call this 'bot valuable to the alliance? I sort of feel that in order to be liked by your alliance partners you have to get points and be offensive. Would you not pick a team with our strategy in the playoffs? Are we worth anything to other teams - do we have any value?
Basically, in the past have the successful teams been the ones with gung-ho offensive tactics that get many points, or can the little guys succeed as well, even though they may not contribute as many points in the end?
Do you need an arm to make a difference in the match? Do defensive, low scoring tactics work? What makes a "winning robot"? What are your thoughts?
Unread 27-01-2005, 23:39
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Do defensive, low scoring tactics work?
you can't remove the tetras as you are describing from what I understand, but yes I believe defensive robots are a very valuable alliance partners....
Unread 27-01-2005, 23:41
You can remove tetras from inside goals (as long as they are not stacked)
Unread 27-01-2005, 23:43
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Funny you should mention that. Check this thread for some related discussion.
-dave
Unread 27-01-2005, 23:59
-dave
Thanks for that Dave!
Unread 28-01-2005, 00:14
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
YES!!!
Defensive tactics most definitely do work. Take a look at the last few years national champions. The scores may not be low, but defense played a HUGE roll in last few Championships.
2004 -All of the alliance's that made it to Einstein had great offensive robots in their alliance(469, 71, 67, 175). What set 71, 494, and 435 apart, was defense. 494 could play defense till the last 20 or so seconds then go hang.
2003- wildstang would get a lead in autonomous mode, then sit at the top of the ramp and defend their lead till the buzzer.
2002- well, there wasn't much anybody could do to stop Beaty
2001-wasn't a whole lot of point to defense here(four on none)
2000- well before my time. Maybe some of the guys that have been around for longer can fill in the gaps.
Defensive tactics work better in eliminations, when all your concerned with is winning. Qualifying rounds are a different story all together.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 28-01-2005, 00:25
Billfred's Avatar
Billfred Billfred is offline
I will argue the case for stacking, just to play devil's advocate.
Suppose Redabot can pick up tetras from the human player, then stack them. We'll say Redabot stacks three tetras. Worst case scenario, Redateam just scored nine points. If it's a row, we're talking nineteen.
Then consider Bluabot. It's a box on wheels. It also takes tetras from the human player, but it sends them underneath the goal. In order to match the scoring potential of Redabot, Bluabot will have to get those tetras under the goal three times as fast as Redabot can stack (as it would have to score nine tetras to Redabot's three to score nine points). If we assume Redabot is making rows, that speed for Bluabot balloons to roughly six times as fast in order to keep pace.
And Redabot's got the advantage of keeping at least those nine points, no matter what happens. So I'll ask the question--do you feel lucky?
Unread 28-01-2005, 00:32
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
but how would the score look if Bluabot played defense and blocked Redabot from scoring any tetras instead of trying to keep up with Redabot. instead of being at a six point (at least!) deficit, blaubot and redabot would break even. blaubot could conceivably cancel out a much higher scoring opponent without ever touching a tetra.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 28-01-2005, 00:39
Billfred's Avatar
This is true--however, this field seems to offer plenty of Plans B. If Bluabot is blocking you, win a shoving match. Or whistle for a partner to come over and dance with Bluabot for a while. Or, retreat and head for the nearest wall--there's three more goals there.
Unless there is a wall involved (and there isn't too much wall this year, as the goals and loading zones take up quite a healthy piece of real estate), it'd take the majority of the Blue alliance to stop one offensive Redabot.
I'll be very interested to see if defense is as powerful as it has been in the past.
Unread 28-01-2005, 00:42
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Bluabot won't be able to completely stop redabot from scoring. There are just way too many goals to try and defend.
The rules, also, lean toward offense, with the rules about the loading zones and de-scoring.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 28-01-2005, 00:53
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah, all redabot has to do is score once then bluabot has to take a break from defending and go and score four tetras to take the lead back, and while it does that redabot goes and scores four more itself, so bluabot has to go and score twelve more giving redabot time to score twelve more..... see a pattern? What happens if a match is tied.... like say tied at 0-0?
Unread 28-01-2005, 04:44
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
I disagree. Remember 2003, the Crates . The stealth hedgehog (our robot) could stack the boxes, but everytime it tried, the stack just got knocked over, by a "defensive" low point scoring robot....
I would like to think that one bluabot could hold up one or 2 of the redabots, giving the rest of redalliance a break to score more points. however, if there is a defensive robot on both teams, then they could just get into a shoving match .. .. ..
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 28-01-2005, 08:02
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
low scoring games work
Unread 28-01-2005, 12:09
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Everybody keeps looking at this argument in an "all or nothing" fashion. I'm personally convinced that most of the elimination matches will involve one of the 3 robots playing "zone defense" on the other side of the field while the other 2 try to rack up points. The difference between winning and losing in many of these matches will be strategy of play.
Unread 28-01-2005, 12:34
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
Ever heard "The best offense is a good Defense."??
If one teams on an alliance is a box on wheels, and the other two can score points, that box can go be a PITA to the other team.. very effective.. just hope you dont get stuck with 2 or 3 boxes on wheels for a match..
j
FIRST Volunteers D. Gregory General Forum 46 10-09-2006 12:53
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Ohmigosh, the scoring at KSC is low!!! (EOM) archiver 2001 1 24-06-2002 01:37
